Technical => Engine Tech => Topic started by: 88 XR7 greg on April 14, 2006, 05:22:15 PM
Title: exhuast
Post by: 88 XR7 greg on April 14, 2006, 05:22:15 PM
i jus wanted to see if i can use a set or bbk 1-5/8" full-length headers on my 88 xr7 cougar
Title: exhuast
Post by: Haystack on April 15, 2006, 06:59:44 PM
you can, but it would be best to use 1 1/2 if you can.
Title: exhuast
Post by: 88 XR7 greg on April 18, 2006, 12:45:30 PM
thank you. the headers are for a mustang but because its the same engine i figured they would fit. could i use a catback for a mustang
Title: exhuast
Post by: Nate on April 18, 2006, 04:18:53 PM
yes, but its going to have to be lengthened. the h pipe will bolt up. and the cat back will be fine, but to join the 2 you need some extra pipe.
Title: exhuast
Post by: Sick88Tbird on April 20, 2006, 12:39:59 AM
1 5/8" primaries are fine for a 5.0.  But if you want to use those headers you'll need to swap in a 5-speed...they don't clear the auto trans...well...a C4 will work too.
Title: exhuast
Post by: 88 XR7 greg on April 20, 2006, 06:04:38 PM
now if i  use 1 1/2 inch headers can i leave it an automatic
Title: exhuast
Post by: Haystack on April 21, 2006, 09:28:09 AM
i assume it is more the brand the size of the pipes. Stock mustang headers fit with some leverage(a big hammer).
Title: exhuast
Post by: thunderjet302 on April 21, 2006, 01:13:00 PM
Mine bolted right in no problem. I think that the only time you run into trouble is if the motor mounts are going bad and the engine has sunk down a little.
Title: exhuast
Post by: 88 XR7 greg on April 27, 2006, 05:27:30 PM
i found a set of bbk headers in jegs and i really want them because i cant find anything for a cougar only mustang parts will show up.
