General => General Fox T-Bird/Cougar Discussion => Topic started by: 88 Blackbird 5.0 on March 24, 2006, 12:20:58 AM
Title: buttstuffog instrument cluster?
Post by: 88 Blackbird 5.0 on March 24, 2006, 12:20:58 AM
Hey guys, is there a certain model, or year 83-86 T-Bird that came with a totally buttstuffog instrument cluster?  Although I've seen a few pictures of T-Birds in that year range with an buttstuffog cluster, most of the cars I've seen, have a partial, or totally digital cluster.  If the Bird I find has a digital steup, is it an easy swap, to replace it with an buttstuffog one?  Not only do I like the looks of the buttstuffog set up better, but one of the things I'd like to do with the Bird I find, is to build a nasty 351 Windsor to drop in between the towers.  I'm thinking that if I build a nasty 351 like that and back it with a stout tranny and rearend.  It will be pretty difficult to use the stock, digital cluster with that set up.
Vic
Post by: srv1 on March 24, 2006, 03:10:24 AM
Vic, all the Turbo Coupes came with an buttstuffog cluster. Are you talking about the V8 buttstuffog cluster? I was told only the 88 TBirds had them.
James
Post by: Haystack on March 24, 2006, 08:44:52 AM
88 tbirds only, however, if you have a 85 up tbird/cougar the will physically fit, but you need difrent sending units(sensors,) like the gas and what not.
If I were you, I would find a full digital cluster. It has more guages then the tubro coupe one, and a built in trip computer.
Post by: EricCoolCats on March 24, 2006, 10:07:29 AM
1985-86 Cougar XR7
1988 Cougar XR7
1985-88 Thunderbird Turbo Coupe
1988 Thunderbird Sport V8
Instructions on swapping over are here:
http://www.coolcats.net/media/base2tc.pdf
Post by: Thunder Chicken on March 24, 2006, 11:20:03 AM
Just a FYI - if you find one with a base (digital speedo, buttstuffogue gauges) cluster it's far easier to do the swap than if you find one with the full digital. With the base cluster the only sender you have to change is oil, while if you start with a full digital car you have to change the oil, water and fuel senders
Post by: Haystack on March 24, 2006, 03:27:40 PM
hmm, good to know.
