General => Lounge => Topic started by: bondocougar on March 18, 2006, 06:40:08 PM
Title: How the heck to get a broke bolt out
Post by: bondocougar on March 18, 2006, 06:40:08 PM
It happened again, a car job that should take a few hours has turned into a multi hour Man Vs Bolt job.
I've got a lot of work to do on the Cougar, so of course by Murphy's law, my daily driver Merc Sable water pump had to go bad.:mad:
Job went well until tightening the last bolt on the new water pump broke off.  A six hour job now has gone on 12, I removed the timing cover, and there is about an inch of bolt still sticking out of the block.
Tried:
1) Vice gripping it out, no luck
2) A drill and a screw remover bit, which then broke in the bolt.  I have NEVER had luck with these screw removers
3) Its been soaking in a mix of WD-40 and 3in1 general oil
I'm thinking of 3) dremel cutting flats on the bolt stud and then trying to wrench it.
[SIZE="4"]Before I do any more damage, whats anyone's experience in the way to get a broke bolt out?[/SIZE]
(http://mysite.verizon.net/junkyardjoe/h2o1.jpg)
Post by: Blackout on March 18, 2006, 06:48:28 PM
Well, it looks like the threads are trashed now.  If you can by some merical get a nut on it, thread it on, weld it to the bolt and then turn it out.  Ive broken water pump bolts before, and thats how I got them out.  If not, heat it up (Keep the flamables away)  spray it with PB Blaster, Seafoam deep creep or another penatrant, and then try to turn it out with the vice grips.  might try that dremel trick first to give you a little flatness to get a grip on.
Post by: Haystack on March 18, 2006, 06:57:15 PM
dremel the sides flat, then try the vise grips again. Maybe a really big set of pliers.
Post by: Tbird232ci on March 18, 2006, 07:06:32 PM
sears might have some bolt extracters that will work for that
Post by: Beau on March 18, 2006, 07:06:53 PM
If you got a oxy-acetylene torch, use that to heat it up, and try it again with vice grips, usually works....
Or have somebody weld a nut on the end, but you'll want to get that bolt heated up, or it'll just break again.
Sometimes they break off somewhat farther into the hole, that's when it gets really fun, usually involving some serious swearing.
Other than that, I couldn't tell ya, sorry man.
Last time I broke water pump bolts off, was on my f-150 5.0 engine, and I didn't have the torch at the time, so I ended up having the local dealership come get it, and while they had it in the shop, they also changed the timing chain, and put a new pan gasket on for me, since the mechanic boogered up the pan gasket taking the front cover off...
Cost a few bucks, too, about more than the truck was worth.
Post by: shame302 on March 18, 2006, 07:07:34 PM
i did this just last week on the wifes car...it usually works fine.
i have also  threaded 2 nuts on and cranked them against each other like crush nuts. depens on what type of brake it is...
Post by: merccougar50 on March 18, 2006, 07:09:24 PM
If you have a welder just weld a nut on the stud.  It does not have to be strait or pretty, so long as you can get a wrench on it.
If not take the dremel and either:  mill two opposing flat sides, and try the biggest pair of vice grips you have.
or cut a slot in the middle and use a flat head screwdriver bit (the type for a ratchet).
Failing that you have to cut it off flat and use a reversing drill bit and an EZ out.  (The cheep ones are , snap on or mac is necessary)
If you have to I would try to borrow a welder before attempting to drill that sucker.  Especially on a FWD car where you will likly need a 90* drill.  I would also be very careful using a Oxy/fuel torch under the hood.  Lots of stuff that will melt or burn.
Post by: Pressure cooked chicken on March 18, 2006, 10:58:30 PM
don't forget that when using vise grips, you can usually make it grab tight enough by first screwing the adjuster in to get a tight grip on the busted bolt. then take a pair of channel locks or another pair of vise grips and crank the adjuster even tighter. that has gotten some seemingly impossible ones for me.
Post by: MexCougar on March 18, 2006, 11:34:38 PM
If you can, follow the welding method. I ruined a bolt in a door in the cougar, and i have tried everything, but i welded a bolt at the end...was a piece of cake...
Post by: Dare on March 19, 2006, 04:05:10 AM
If all else fails,  cut it flush,  drill it out and tap some new threads.
Post by: SLEEPER T-BIRD 87 on March 19, 2006, 04:15:32 AM
Hand held propane/map gas torch will be your friend. heat the base were it goes into the block till cherry red. Take your vise grips and twist it out. works 99.9% of the time.
Post by: bondocougar on March 19, 2006, 07:22:53 PM
This board is awsome!  Thanks alot all!!!!!  :bowdown:  :bowdown:  :bowdown:
I don't have a welder, so that limits what sounds like the easiest option.
So I tried the propane torch.  I had a bucket of water and a fire extinguisher ready, as with my luck :bricks1: I envisioned the whole car catching fire, followed shortly therafter by my house.
I propane torched it for a long time, sprayed it, and then repeated this 3 times before I tried vice gripping it out again.
I can't tell you how happy I was to see that B@stard starting to turn out!  So that heat definitely loosened it.:giggle:  The thought of it turning to the re drill & tap the block condition Dare said scared the heck out of me, as it sounds so hard to drill it out & re-tap.  Fortunately I live another day to not have to try that!
Thanks!
Post by: Beau on March 19, 2006, 07:59:57 PM
glad to hear ya got it :D
amazing what heat'll do to rusted/sheared off bolts, etc
Post by: cougarcragar on March 19, 2006, 08:36:06 PM
Quote from: bondocougar
Right on, man. There's no better feeling than to see something finally work out in your favor. Glad you got it taken care of.
Post by: SLEEPER T-BIRD 87 on March 19, 2006, 09:41:51 PM
Thanks!
Gld you got it out:D
They dont calla torch a heat wrench for nothing:flame: :flame:
Post by: Funky Cricket on March 20, 2006, 01:51:05 PM
thats the only way I can ever get the brakes of my wifes monte carlo..
go go magic propane torch!
Title: A $13 Bolt!!!!!!!
Post by: bondocougar on March 21, 2006, 01:19:17 AM
Good Gawd!!  :barf:
Ford wants $13 EACH for these water pump bolts.. They look like 1.25mmx8 weird bolts, not the sort of thing you get at Home Depot!
So much for the idea of doing the job right and getting ALL SIX :yuck:
Also, couldn't order one, minimum buy was two!!!
Post by: SSX on March 21, 2006, 02:44:00 AM
What is it with those water pump bolts?  I had trouble with mine a month ago too.  Ended up having to heli-coil it and found a stud at tractor supply.  Couldn't find the right size nut to fit between the ac bracket and the pump, so I had to use two locking washers.  It's a bit ghetto, but it works fine so I don't care.
