Technical => Electrical Tech => Topic started by: LSX on March 08, 2006, 07:46:15 AM
Title: Sensor Location for Full Digital Dash?
Post by: LSX on March 08, 2006, 07:46:15 AM
I have the opportunity to get a full digital Dash off a 88 Cougar to replace my base dash.
I need to know where the water and oil sensors are located..
I presume the fuel is with the pump (i may be wrong).
Can anyone help ?
The tach is another problem i'm working on ....
Thanks in advance
Post by: Thunder Chicken on March 08, 2006, 08:42:18 AM
The water and oil sensors are in the same place they are with your existing dash - the oil is down by the filter, the water should be on the intake manifold near the water neck (I'm not sure about that one, though).
The fuel sender is in the tank, and it's separate from the fuel pump bracket - if you drop your tank you'll see two "senders" - you want the smaller one.
The tach wire simply connects to the green/yellow wire on the ignition coil. You'll also need to connect to the wire at pin #34 (fuel flow) at the ECM to get the tripminder functions of the full digital working.
Post by: LSX on March 08, 2006, 07:24:38 PM
Thunder Chicken
I've read the Instrumentation guide on your website. I know you states that a V6 cluster wont work on a V8 and visa-versa. But why wont it?
I checked with a  Ford Parts Dept. today, they only listed one full digital cluster part number (can't get one of course).  Do you know if there is (if you know where is it ?) a component wired up or taken out between the two of them?
Basically what I'm geting at is, I have a chance to get a v6 Full Cluster and i want to put it on the 5.0.
I've diving into some new territory here and help is always appreciated.:bowdown:
Thanks in advance
Post by: raser13 on March 08, 2006, 08:50:41 PM
actually the full digital will work on a v-8. i took one off  of a v-6 and put in there the only major mod is to ground the tach on a different pin i dion't remember wich one it is but the guys here were nice enought to help me  theey should be able to help. any one know the right pin??? push come to shove i take the cluster out and find it.
Post by: Thunder Chicken on March 08, 2006, 08:53:30 PM
The V6 cluster will have a tach calibrated for a V6. If you install it on your V8 it will work but the tach will read wrong.
I vaguely remember reading somewhere that the tach can actually be calibrated for any engine by using a certain terminal on the cluster connector (called the "tach strap") - you ground it for one engine, leave it disconnected for another, and connect it to positive for another, but I forget which is which and which terminal to use. I think the info was on the old board - perhaps Masterblaster can help?
*edit* Raser13 beat me to it :D
Post by: raser13 on March 08, 2006, 09:03:50 PM
yeah thats what i did for mine i just can't remember wich one to ground for v-8. also if your swiching to digital don't forget to do the 199 mile/hour mod from bondocougar. by the way you do realize this mean a complete rewire of the clip behind the cluster right.
Post by: LSX on March 08, 2006, 09:18:39 PM
Yeah I didn't think it was a P'n'P job, but what the fun in that.
Actually I'm doing all the reaseach throughly before I cut any wires.
Since the interior has to be worked on anyway I figured it woud be the best time to start.
Believe me this job will probably be easy compared to my final modifications to the car. Bascially i'm putting parts on the car that was never engineered to have been on their (or even on a car ) in the 1st place. (and no it not a plyboard spoiler :yuck: )
I just wish I could work for Ford and do stuff like this.
Post by: MasterBlaster on March 09, 2006, 10:03:58 AM
:D
87cleveland
Registered User
(1/10/04 9:09 am)
Reply
Re: 6 cylinder digital tach to 8 cyl.?
Changing the cluster will not change the tach operation, you will need to add a ground to the tach strap 1 pin in the back of the cluster. here's the breakdown:
ground tach strap #1=V8
ground tach strap #2=4-cyl.
ground neither=V6
I have tested this several times and it does work. I can't remember which one of these engines it reads for when you ground both straps but that's really not important.
P.S. Eric, if you're reading this, this might be a good thing to add to your site along with the speedo modification and digital cluster swap instructions
Daryl
the fuel flow goes to pin #34 on the engine control module(if you take the connector off you can see the numbers) both tach straps are on the grey connector(left side)
pin #8 is tach strap #1 make sure it runs to a ground
pin #9 is tach strap #2 make sure it does not go to a ground
you can install or remove these anytime without frying anything
Daryl
Let me try this again. There is only one full digital cluster, it can be used on 4, 6, and 8-cylinder engines. The presence or absence of grounds at the back of the cluster determine for which engine the tach is calibrated.
Daryl
I'm gonna try this, you will need:
1. a fuel tank sending unit from the donor car
2. a coolant temperature sensor-this is a two wire sensor used by
the EEC, not the one-wire sending unit you are using now
3. an oil pressure sending unit for a car with buttstuffog gauges
4. the new cluster with both connectors(be sure to cut the harness
as far back as possible)
5. 3 miles of automotive wire, I'd also recommend shrink tube and
solder
The worst part of this project is changing the fuel sending unit(dropping the tank), the rest just takes some patience. Replace your one wire temp sender with the two wire temp sensor(#2). Hook the original wire to one side and ground the other side. Your parts car may have the sensor and the pigtail for this. Replace your oil pressure sending unit with #3. Pull the old cluster. Use these as a guide to rearrange the wires:
http://www.coolcats.net/tech/general/base.html
http://www.coolcats.net/tech/general/digital.html
You will need to lengthen some and remove others. The fuel flow wire comes from pin #34 on the EEC. You will not need either tach strap. Let me know if I need to clarify anything.
Daryl
Post by: raser13 on March 09, 2006, 05:44:47 PM
thanks masterblaster for clearing that up . i knew someone had told me on the old board how to do that. i just couldn't remember wich one i had to ground.:bowdown:  :rollin: :headbang:  :banana: :banana:  :cheers: :cheers: :drink: :drink:
Post by: LSX on March 09, 2006, 06:01:46 PM
masterblaster
Thanks for the info
FYI- The links for the diagrams are non functioning. The documents dont exist.
I'll let you guys know the progress and document as much as I can for a guide.
Post by: MasterBlaster on March 10, 2006, 11:00:33 AM
Should be working now.
The updated links now match Eric's updated site.
Post by: LSX on March 10, 2006, 03:39:46 PM
Bingo
Thanks as Always
Post by: raser13 on March 10, 2006, 10:45:54 PM
heres the updated links eric has redone his site since that post was done. for the digital  wiring diagram http://www.coolcats.net/tech/general/digital.html and for the base http://www.coolcats.net/tech/general/base.html that should do you any other questions give us a post.
