Technical => Engine Tech => Topic started by: lockedout9 on February 27, 2006, 12:30:55 PM
Title: Max Compression Ratio
Post by: lockedout9 on February 27, 2006, 12:30:55 PM
I'm planning on rebuilding the SO 5.0 engine in my 87 tbird to the HO varity.  Depending on which combination of parts the compression ratio can vary from 8.7 to 12.0.  I want to continue using the 87 octane pump gas but while I'm asking I might as well ask for the other octanes.
If you please would answer, What is the max compression ratio the 5.0 HO engine can take that won't cause pinging/detionation using the 87, 89, and 92 octane gasoline?  Also does engine cubic inchs make a difference?  Was considering stroking the engine.
Post by: the_intimidator03 on February 27, 2006, 12:34:48 PM
I'd say 10:1 is safe bet on 92 any more u can be pushin it... and altitude will have some bearing on it.  dont think cubic inches gonna make much of ad ifference... u can get octane booster tho... and play with timing... but there is pro's and con's to playin with timing which i do not know but someone else will.
Post by: Red_LX on February 27, 2006, 01:18:10 PM
Cubic inches only really matter in that the bigger the engine, the more power you can make on lower compression. I.e. a big block can make 400 hp on 9:1 easy, whereas with a small block that would be harder to do.
Post by: lockedout9 on February 27, 2006, 06:50:39 PM
I want to stay with 87 octane because this is a daily ride.  Sure don't want to be adding octane boost.  That would send me to the poor house.
Post by: Red_LX on February 27, 2006, 10:32:53 PM
On 87, my guess would be that you probably wouldn't want to run more than about 9.5:1.
Post by: lockedout9 on February 28, 2006, 03:51:40 PM
9.5 is good.  Glad I found out before buying the wrong heads with smaller cc.
