General => General Fox T-Bird/Cougar Discussion => Topic started by: Beau on February 26, 2006, 05:21:54 AM
Poll
Question: 5.0 SO ..or 5.8/351w
Title: 5.0 or 5.8?
Post by: Beau on February 26, 2006, 05:21:54 AM
I have a chance to snag a 5.8 out of a 91 3/2 ton truck, was wondering how many would put the 351w in a Tbird, as opposed to a stock 5.0 SO.
The 5.8/351w will be cammed, carbed, headers, and Edelbrock Performer RPM intake, and something around a 650 to 750 cfm carb, and an otherwise stock bottom end. Maybe some polishing on the heads if my budget allows. After all, I gotta buy special oil pan and headers for this...
The other option is a stock 5.0 SO out of another Sport, and nothing done to it...
What would you guys do?
(I've really been wanting a Thunderbird with a 351 forever...just want a few opinions why/why not.
Title: 5.0 or 5.8?
Post by: Haystack on February 26, 2006, 06:59:47 AM
hmm I could see how the gas sitiation could suck with a carb, but either way I am sure you will be pleased. Parts from boh engines interchange, so I say both ;).
I would go fuel injected 5.0, unless a carbed 351 is something you can afford.
Title: 5.0 or 5.8?
Post by: Beau on February 26, 2006, 07:34:09 AM
I guess I should have put in a third choice:
5.0 HO from '87 or '88 Mustang, and ecm.
I think this may be my best choice, only other thing I'll need for this one is an exhaust setup.
Only thing is, with the HO instead of the SO, I won't get the motor mount plates to drop it in...
And I have no clue where to get them, w/o buying a motor to go with 'em (jy guy won't just sell me the mounts/brackets...)
Title: 5.0 or 5.8?
Post by: V8Demon on February 26, 2006, 09:08:21 AM
I say go 351.  I'd go fuel injection though.
Title: 5.0 or 5.8?
Post by: Haystack on February 26, 2006, 09:09:59 AM
or you could always throw a 347 stroker kit at the stock tbird block and call it a day.
Title: 5.0 or 5.8?
Post by: Beau on February 26, 2006, 09:31:36 AM
Paul Flockhart-I say go 351. I'd go fuel injection though.
-I'd eventually like to do that, but right now, I just don't have the budget for an EFI 5.8, what with the u/l intakes I'd need.
Haystack-or you could always throw a 347 stroker kit at the stock tbird block and call it a day.
-Another good option, but really don't have the money for that either...
I gotta budget of about 800 bucks, but part of that is already going toward new shocks/struts.
Way I figure, if I can find a decent SD 5.0HO somewhere for around 400 or so, and a SD HO computer, that's probably all I be able to get till I can either find full time work, or else save enough.
The thing is though, I traded a car awhile back for some other parts, but the guy can't come through on some of the stuff, so he's giving me a 351 out of a 91 3/4 ton truck, and it's complete.
The only costs would be the headers, oil pan, carb, motor mounts/brackets, and some sorta ignition. I already have an intake for it...
Another option is a 5.0SO for 150 bucks, but no guarantee it will run, as it's been in a jy for awhile, and he bought the car with no trans. in it. Hence the reason I can't hear it run. I tried to buy the whole car from him awhile back, but he couldn't/wouldn't sell it. (87 or 88 Sport)
That's why I figured on doing the 5.0SO, and then over time, getting all the parts needed for the HO conversion.
The Tbird is my usual transportation, so I really don't like the idea of  it sitting around too long, and the plates are up for renewal at the end of March anyway. So whatever I do, it'll have to be done by then. But anyway, thanks for the ideas :D
Title: 5.0 or 5.8?
Post by: Haystack on February 26, 2006, 09:38:21 AM
hmm, for a DD, I would go stock or H.O. 5.0. Just because there is alot more information out here on how to do it. Also, better gas miliage and things of the like.  I havent had too many problems with my cars. I have pretty much always been able to at least get the car home. How many miles are on the engine about?
Title: 5.0 or 5.8?
Post by: Beau on February 26, 2006, 09:43:06 AM
on the 5.8, about 75,000
on either 5.0, I have no clue, havn't located an HO yet, and the Sport that has the SO, I havn't seen the car but from a distance.
Title: 5.0 or 5.8?
Post by: shame302 on February 26, 2006, 11:04:31 AM
well, first instinct would be to say 351, no brainer. but in your sitch. the 5.0 HO seems like it would be the best deal. id forget about the SO.
man...if you were closer to me id sell the whole drivetrain to you for 500...engine, mounts, all the HO parts, exaust,, T5.
all you would need is gaskets, resurface the HO heads and assemble....
Title: 5.0 or 5.8?
Post by: Beau on February 26, 2006, 11:08:23 AM
Wish I had the $$ for gas to drive there and back, that's pretty much all the stuff I want to put in my car...
Title: 5.0 or 5.8?
Post by: shame302 on February 26, 2006, 11:11:55 AM
oh...you would still need the clutch pedal assy and cable. it would probably cost another 300-400 to ship though :(
Title: 5.0 or 5.8?
Post by: Beau on February 26, 2006, 11:22:25 AM
If I didn't need shocks, struts and a coupla new tires, I'd consider it...
probably cheaper to ship it than for me to drive there...
Ah hell, there's gotta be an HO somewhere around here..
Title: 5.0 or 5.8?
Post by: shame302 on February 26, 2006, 11:43:49 AM
im sure there is....
Title: 5.0 or 5.8?
Post by: Red_LX on February 26, 2006, 01:25:59 PM
Don't forget that a 351 is also 2" taller than a 302...will it clear your stock hood? Well, with a carb you could always use a drop base air cleaner, but with EFI that will be an issue.
Title: 5.0 or 5.8?
Post by: Nate on February 26, 2006, 07:16:31 PM
what ever you do, i'd keep the fuel injection
Title: 5.0 or 5.8?
Post by: 302Fairmont on February 26, 2006, 10:34:06 PM
Do a 351, you can always put the right EFI stuff on there later.
A 5.0 HO sounds like a solid route too, though.
Title: 5.0 or 5.8?
Post by: kewlbird08 on February 27, 2006, 12:05:42 PM
Go with a 5.0!  But only because I have a 351W going in next summer...
Title: 5.0 or 5.8?
Post by: CougarSE on February 27, 2006, 12:15:42 PM
Go 351 but do what nick did and use a carb intake and weld injector bungs on it.  I would use an accel 4bl throttle body though.  It would keep the height down.
Title: 5.0 or 5.8?
Post by: SirChirpAlot on February 27, 2006, 11:47:14 PM
Well i would say 351 hands down.
I might be wrong but i'm sure a 91 351 would be roller.
Just swaping in a b303 some head work and a good intake would wake that motor right up.
I do side with the bigger is better idea's
Title: 5.0 or 5.8?
Post by: phyxius on February 28, 2006, 12:24:57 AM
i'ld go 351 EFI  just for the fact a friend has one and is getting all most 28-30 mpg.the engine hardly works at all  and now i ma do it  to my 85 XR-7 i have had a 351 fuelie with 5k sitting in my shed for a year.
Title: 5.0 or 5.8?
Post by: 84t-bird on February 28, 2006, 12:50:43 AM
id go with a 300 inline six.:evilgrin:
Title: 5.0 or 5.8?
Post by: CMQuickcoupe on February 28, 2006, 07:22:20 PM
Quote from: SirChirpAlot
I agree bigger is better.You cant go wrong because the 351 has more tork than the 302 because of the stroke and rod length and this leads to qicker take offs for the weight of these cars and thats where it all starts at for performance.As far as a 91 351w it will be a flat tappet design camshaft because the windsor roller blocks did not start until 94 as far as I have seen.These blocks are fairly hard to come by but you can get around that with a new set of lifters that comp-cams makes that are retrofit hydrulic rollers connected by a swivell bar so you can run any year of block with a hyd. roller camshaft.They are a little expensive around 300 bux or so,so you have to decide what size engine you want and how much you are willing to spend.
Title: 5.0 or 5.8?
Post by: fordguy on March 02, 2006, 11:03:13 AM
i look at it this way. if you have the money for all the parts you need, oil pan, headers, ect, go for it. but if you have to spend the money on that stuff, go with a 460. you will not be dissapointed. gas mileage won't be fantastic but you will not be able to get the smile off your face! trust me :)
Title: 5.0 or 5.8?
Post by: Ether947 on March 02, 2006, 11:57:31 AM
i say 5.0 HO for a DD. or at least swap over some parts from the HO to the SO and make it a good, reliable, low budget transportation.
