Technical => Drivetrain Tech => Topic started by: 4mykid on February 04, 2006, 07:41:53 PM
Title: 3.27 gears
Post by: 4mykid on February 04, 2006, 07:41:53 PM
iis it unusual to find 3.27 gears in an 87 t-bird that originally had a 3.8 v6. The tag on the bach of the rear end deffinatly says that it is 3.27? and the sticker in the door has a 5 in the axel location, from info i have researched that tells me it is a 3.27 gear set.
Title: 3.27 gears
Post by: V8Demon on February 04, 2006, 08:24:39 PM
Tow package came with 10 inch brakes and 3.08 or 3.27 gears...
Title: 3.27 gears
Post by: CougarSE on February 04, 2006, 11:37:05 PM
My car has a 3.27, but my door code is an E, cause its locking.
Title: 3.27 gears
Post by: V8Demon on February 05, 2006, 02:34:40 PM
If 4mykid got a car with 3.27's from the factory it SHOULD also be a trak-lok
Title: 3.27 gears
Post by: CougarSE on February 05, 2006, 05:07:03 PM
Paul a door code 5 is a conventional 3.27.
4mykid, does the tag on the rear end read as 3 C 27 75  ?
 Mine reads as a 3 L 27 75
Title: 3.27 gears
Post by: V8Demon on February 05, 2006, 05:10:32 PM
Wow, guess some of the v6's snuck out of the factory with peg leg 3.27's:screwy:
Title: 3.27 gears
Post by: 4mykid on February 06, 2006, 07:07:07 PM
Actually it says  3 . 27 75 7C13, there is no L or C its just a dot in that location? who knows! I would imagine that the door code is correct though.
Title: 3.27 gears
Post by: fordman3 on February 28, 2006, 07:18:08 PM
My '84 Cougar LS 3.8 AOD has an open 3.27.  Don't know if it came with a towing package.
Fordman3
Title: 3.27 gears
Post by: Thunder Chicken on February 28, 2006, 11:12:38 PM
I used the gears out of an '87 V6 'Bird in my '87 Sport when I replaced the 3.08's with 3.27's (Normally I wouldn't have bothered with such a minor change but the whole rear end was being redone anyway - new axles, bearings, seals, etc, so I had the shop class do it as a project). The donor rear was an open one, I know this because when the junk yard sent the gears they sent the whole diff attached to the ring gear
Title: 3.27 gears
Post by: Bird351 on February 28, 2006, 11:17:53 PM
Quote from: Paul Flockhart
All four of mine (yes, even the Marks) apparently have opens. Think I have three 3.27 rears and a 2.73 in the V8 T-bird.
Title: 3.27 gears
Post by: V8Demon on March 01, 2006, 04:11:14 PM
My old v6 was a trak-lok equipped car with 3.27's.....It had 9 inch rear brakes though.  I thought that was a rather odd combo.
Title: 3.27 gears
Post by: Tbird232ci on March 01, 2006, 04:22:39 PM
all 87 3.8L's got 3.27's
they put 3.27's in the rear of the 87's to help combat the extra weight they stuck on the 87's. Then in 88, they got 20 more horsepower, so they got 2.73's once again.
