Technical => Drivetrain Tech => Topic started by: BobNorway on January 27, 2006, 02:09:42 AM
Title: TV cable
Post by: BobNorway on January 27, 2006, 02:09:42 AM
Hi, has anybody tried a Lokar TV cable LOK-KD2AODHT (Summit number) on  87 Tbird with 5Ltr EFI AOD trans?
Title: TV cable
Post by: EricCoolCats on January 27, 2006, 09:02:51 AM
I have heard from a few people that yes, it does indeed work.
Title: TV cable
Post by: Warbird9 on January 27, 2006, 12:09:02 PM
I used one on my 87 sport 5.0, but had to tweak some brackets to mount it. I have to adjust some file sizes to post some pics, but I can if  your interested.:D
Title: Bracket?
Post by: BobNorway on January 28, 2006, 07:14:34 AM
Did you buy the lokar bracket also? (TCB-40EFI)
Tweaking is ok as long as I can get it to work.
Pics would be great if you get the time.
Mine is now held in place with a Levis button, which just happens to be the right size.
Fords plastic bushing was not an 18 year solution.
Title: TV cable
Post by: cougarman on January 28, 2006, 08:16:00 AM
You can still buy new bushings from Ford, about $2 ea..:D
Title: Thanks
Post by: BobNorway on January 29, 2006, 10:08:47 AM
Thanks for the tip.
Have you got a part number for the bushing?
Title: TV cable
Post by: cougarman on January 29, 2006, 10:20:05 AM
EOAZ-7F330-A
Insulator          :D
Title: Thanks
Post by: BobNorway on January 30, 2006, 04:00:09 AM
Thanks again.:D
Title: TV cable
Post by: cougarman on January 30, 2006, 10:43:01 AM
You're welcome. :D
Title: TV cable
Post by: waferman on January 30, 2006, 10:53:47 AM
i need that bushing...thanks for the part number.
Title: TV cable
Post by: Warbird9 on February 03, 2006, 12:05:36 PM
Sorry for the delay in posting these pics, hope they can be of use to someone.
First pic shows the piece I made to adapt the Lokar hardware to the factory accelorator/ kick-down bracket:
second and third show the adapter on the factory bracket:
Title: TV cable
Post by: Warbird9 on February 03, 2006, 12:15:46 PM
The next two pics are of the Lokar bracket attaching the cable to the tranny boss, but I felt it wasn't lining up right, so second pic shows the cable with the factory bracket. Worked much better that way I think. Last pic shows the connection for the cable on the throttle plate. The stud for connecting the cable to the throttle plate was to long and the ny-lock nut washiznitting the adjusting screw, so a little spacing with a s piece of hose worked nicely.
Title: TV cable
Post by: BobNorway on February 05, 2006, 05:54:15 AM
Wow,
Thanks for the pics. I putem in a safe place.
I'll do the bushing thing first and see what happens.
