Technical => Drivetrain Tech => Topic started by: BadCat on November 29, 2004, 05:38:49 AM
Title: Transgo shift kit
Post by: BadCat on November 29, 2004, 05:38:49 AM
Can I safely remove the tv cable after I install my new shift kit?  I heard that you can but I want to be absolutely sure because I don't feel like buying another tranny.
Title: Re: Transgo shift kit
Post by: zpyro on November 29, 2004, 05:40:44 AM
I don't think I'd chance it. why would you want to do that? it really isn't hurting anything, and there's a good chance that removing it would fry your tranny by the time you get to the corner.
I have heard someone say that having the shift kit keeps the pressure high enough so that the tranny didn't fry when the TV cable came off accidentally, but like I said, no reason to chance it. trannys aren't cheap (oh how we wish they were :p)
Post by: BadCat on November 29, 2004, 02:59:52 PM
That was basically my whole point of getting it. That tv cable has to come off it is stretched too far. I can't adjust it, its superglued, gummed up or something, it wont budge.  At Wot I shift around 6k which is way too high. I tried letting off for it to shift but it didn't help any. I still run a full second slower than I used to because of that  cable.
Post by: Ifixyawata on November 29, 2004, 07:20:11 PM
Shiftkit's do not replace the TV cable.  Get an aftermarket cable from Lokar.
Post by: TurboCoupe50 on November 29, 2004, 07:42:06 PM
The Trans-Go shift kit will raise the line pressure to a point that the trans will not slip in normal driving(at least mine does). What will happen if you do not use a cable at all, is the trans will shift waaay to soon. Assuming you have a column shift, and with out it connected to the throttlebody, the TV lever at the tranny is full on causing late/hard shifts. The shift kit will not correct for this, you really need to get another cable.
Post by: chrome302jr on November 29, 2004, 10:27:07 PM
What Tom said, I can vouch for this one...Do NOT remove the TV cable. Get a new one and make sure its adjusted properly. With it disconnected you will get really harsh/late shifts.
Post by: BadCat on November 30, 2004, 09:02:33 AM
Allright, looks like I'll be ordering the Lokar cable from Jeg's.  On Lokar's FAQ page it says you need an OTC tool and a pressure gauge to adjust it properly. What is an OTC tool? And I'm not going to adjust it that way. I figure I will adjust it little by little until I find the perfect shift points.
Post by: zpyro on November 30, 2004, 12:51:11 PM
http://www.baumannengineering.com/tvlnkage.htm
http://www.tciauto.com/instructions/431000_inst.htm
when I installed my tranny I had a tranny shop adjust the TV cable, no idea how much it was
Post by: TurboCoupe50 on December 02, 2004, 12:00:11 AM
Adj the cable so that it is at full travel at full throttle. Set this way there will be no chance of it slipping and burning up.
