Technical => Electrical Tech => Topic started by: mpd86 on January 17, 2006, 08:13:49 PM
Title: EEC Location
Post by: mpd86 on January 17, 2006, 08:13:49 PM
My cougar is a 1986 with a 3.8L with an automatic. Where exactly is the EEC and how do you go about getting to it ?
Thanks.
Title: EEC Location
Post by: Thunder Chicken on January 17, 2006, 08:41:49 PM
Remove the passenger side kick panel and you'll find the EEC behind it
Title: EEC Location
Post by: 5.8fastcat on January 17, 2006, 08:53:26 PM
Should be in the pass side kick panl below glove box. Remove kick pnl and remove black platic cover if still there. Takes a 8mm or 7mm screw and pull down on it
Title: EEC Location
Post by: Lx-tasy on January 17, 2006, 09:06:09 PM
The cover is held in by a 5.5mm screw and the EEC itself takes a 10mm wrench or socket to get out.But its behind the pass. side kick panel.
 Chris
