Technical => Drivetrain Tech => Topic started by: 88turbo on January 04, 2006, 09:40:10 PM
Title: aftermarket clutch for TC
Post by: 88turbo on January 04, 2006, 09:40:10 PM
does anyone know where to find an aftermarket clutch for a TC?  also looking for a flywheel thanks.
Post by: Tbird232ci on January 04, 2006, 10:04:30 PM
http://www.s-rracing.com/
centerforce also makes one
Post by: 88turbo on January 04, 2006, 10:54:50 PM
thanks shawn
Post by: Red_LX on January 04, 2006, 11:15:04 PM
As far as clutches go, Centerforce, Spec, Ram and Luk all make clutches for the 2.3L, but I can't say I know how great they all are. I have a Luk but I think it is pretty much a stock replacement clutch.
For flywheels, Esslinger and I think Racer Walsh both have aftermarket flywheels, but they are definitely not cheap.
Post by: 88turbo on January 04, 2006, 11:16:44 PM
money isnt a problem......
Post by: Tbird232ci on January 05, 2006, 09:14:10 AM
an aluminum flywheel is nice, but can be a royal bitch to drive
Post by: Chuck W on January 05, 2006, 09:38:09 AM
You can get a new flywheel at NAPA or the like.
Post by: Graham on January 05, 2006, 11:30:52 AM
I'm more that happy with my Spec 3 in my TC. As for a flywheel, Chuck has the right idea. Although, I couldn't find one in Canada, crossed the boarder and got a new one at Advance for $39 I believe.
Post by: 88turbo on January 05, 2006, 07:42:31 PM
what I have found so far for the clutch and flywheel together is about 600.  where do you get these Spec 3 clutches?
Post by: Pressure cooked chicken on January 05, 2006, 09:05:20 PM
centerforce stage 2 here. put it in almost 2 years ago. about 25,000 miles and about a dozen dragstrip passes later still working great. think i spent around 400 bucks or so but i replaced clutch, pp, t/o bearing, pilot bearing, clutch fork, and t/o bearing retainer so not too bad imo.
Post by: 88turbo on January 05, 2006, 09:43:41 PM
doesnt sound too bad, I know I am gonna need a new flywheel the last time I was in there it wasnt looking good but I didnt have a choice but to put it back together.  so new everything this time. where do you find the pricing for the centerforce clutches?
Post by: Graham on January 06, 2006, 05:19:34 PM
You can get a Spec from Scott at S&R.
Post by: Pressure cooked chicken on January 07, 2006, 10:21:18 PM
IIRC i got the part # from centerforces website and ordered it thru summit. hope this helps.
