Technical => Engine Tech => Topic started by: Nate on December 25, 2005, 01:10:48 AM
Title: porting cylinder heads
Post by: Nate on December 25, 2005, 01:10:48 AM
anybody know the cost of a port job? no bigger valves, or new springs, or what not. just porting, maybe a polish. im look'n at do'n it to a V8, set of  5L heads. world winsor jr's. i cant seem to find any cost charts online, or posts about it.
Post by: screaming306 on December 27, 2005, 08:14:30 AM
you know you can gasket port match them on the intake and exhuast side yourself. i used my dremal tool and a carbine bit from a shipyard. just put the gasket on the head using bolts to hold exactly where the gasket goes.. then mark with a scribe or a blue marker or spray paint the opening at the ports. then remove the gasket and start porting.. if they are stock ford heads..grind down that stupid emission bump on the exhuast ports..
Post by: Ether947 on December 27, 2005, 01:30:59 PM
they are world winsor jr heads, which is prolly the reason why he doesn't want to do it himself.
Post by: Sumthin Nuu on December 29, 2005, 09:49:46 PM
Probably $250-350 to do bowl work under the valves, transition that to the exhaust and intake ports, and slightly open the intake and exhaust ports. If the heads already have a good 3 or 5 angle valve job, nice valves and hardware, I'd say spend the bucks. If they dont, I'd say save the money and run em as is until you can get aluminum heads and sell the others.  Not many guys like porting cast iron anymore, everyones spoiled with aluminum. I know I dont miss porting iron heads that much anymore. Also, I polish the chambers on every head I port to get rid of any nasty slag from the top valve seat cut to the chamber. Most places dont but its not something to skip. Good luck.
Post by: BogusSVO on December 29, 2005, 09:54:48 PM
around here I get $425.00 to do a set of V8 heads, that includes a before and after on the flow bench and a cc of a exhust runner, intake runner and combustion chamber,
and ya will have to have a valvejob also, ya cant help but to touch a seat.....
