Marketplace => T-Bird/Cougar Parts & Cars WANTED => Topic started by: JaysCat on November 07, 2005, 01:43:41 PM
Title: WTB: 88 Cougar keyless entry keypad
Post by: JaysCat on November 07, 2005, 01:43:41 PM
I am looking for a keyless entry keypad with complete harness. I had got one from E-bay, but the harness was about 18 inches too short, and had a different plug on the end. Must have been from another Ford vehicle. Also it would not fit in the door opening unless it was upside down. So this part must be Cougar specific.
Post by: vinnietbird on November 07, 2005, 04:16:17 PM
I have one from a Lincoln Mark VII (1987).
Post by: JaysCat on November 07, 2005, 08:43:14 PM
Does it have the notch that holds into the door on the side with the 9/0? The one I have is from a Lincoln, the notch was on the 1/2 side. The only way it would fit was upside down. On a cougar unit the side that has the notch (9/0) measures 3/4 inch wide and the opposite side measures 7/8 inch (1/2).
Post by: vinnietbird on November 07, 2005, 11:31:43 PM
I'll pull it off tomorrow after work and let you know.I have no idea at this moment.It is in excellent shape though.
Post by: BogusSVO on November 09, 2005, 07:42:16 AM
will one from a T-bird work???  Let me know
Post by: JaysCat on November 09, 2005, 08:17:24 PM
Quote from: BogusSVO
I am not sure, as long as the tang which I have the red arrow pointing to, is on the side with the buttons 9/0 it should work.
