General => User Rides => Topic started by: beaterjeep on October 13, 2005, 07:24:39 PM
Title: My current '86
Post by: beaterjeep on October 13, 2005, 07:24:39 PM
Well folks, I finally got around to taking some pics of my current '86 Cougar.  I know it's not much to look at but, hey, it's bought and paid for, right?  Feel free to criticize all ya want, I need some ideas, lol.
Post by: beaterjeep on October 13, 2005, 07:26:15 PM
Sorry about the funky pic sizes, had to get them under the 19.5 K limit. Anyways, heres a couple more
Post by: 5.0willgo on October 13, 2005, 09:23:26 PM
It's not bad. I'd get it out of the weeds though...
Post by: CougarSE on October 14, 2005, 01:35:31 AM
Hmm tiny pictures but all looks good.  Just get it out of the weeds!
Post by: armyguy298 on October 14, 2005, 09:48:25 AM
Get it out of the weeds, give it a good wash and a tune-up. At least you can make a list of where you need to start. Try to put together a goal for the future and make sure your upgrades steer in that direction! Good Luck! I have an 86 as well.
Post by: Funky Cricket on October 14, 2005, 10:07:17 AM
go 4 eyes! and get it out of the mud and weeds!!! :P
Post by: armyguy298 on October 14, 2005, 02:06:20 PM
Hey Venom, you anywhere near Tomah or Sparta?
Post by: jkirchman on October 14, 2005, 03:55:39 PM
Needs less weeds.
Post by: t-bird85 on October 14, 2005, 04:09:32 PM
Ill post some before and after pics of mine, youll be amazed what alot of money and a little time will do :)
Post by: beaterjeep on October 14, 2005, 11:17:40 PM
Quote from: armyguy298
Actually those pics were taken at a friends house where I'm storing it until spring (doesn't run and don't have money to get it running right now) and that is in Pepin, but I myself actually live inbetween Eau Claire and Menomonie, small place called Elk Mound.
Post by: beaterjeep on October 14, 2005, 11:23:12 PM
I'll also try to get some better size pics on here, just cuz I don't remember seeing another cougar like mine.  With the two-tone paint like that, the built in kinda headrests in the back, coach lamps inside and out, and especially the two-tone dash.  Also it has really narrow trim on the sides, nowhere near as big as the trim on my old '86.  All that and NOWHERE on the car does it indicate whether it is a GS or an LS. (originally came with a 3.8).
Post by: beaterjeep on October 29, 2005, 05:28:52 PM
Okay guys and girls, here they are as promised, bigger hopefully better pics of my current '86.  Let's just hope this works right.
Post by: beaterjeep on October 29, 2005, 05:30:20 PM
some more
Post by: beaterjeep on October 29, 2005, 05:31:26 PM
and yet some more
Post by: 5.0willgo on October 29, 2005, 05:47:10 PM
The same pictures as the small ones. Looks good. Have you managed to get that thing unearthed yet?:giggle:
Like someone else said, dig it up, give it a good bath and a tune up. How long has it been since it was last started?
Post by: beaterjeep on October 29, 2005, 05:53:46 PM
Quote from: 5.0willgo
Pretty much the same ones as the small ones, yes, but I did add a couple of the motor as well.  No, it's not unearthed yet, although I'm hoping it will be soon as I'm getting ready to put it on blocks and store it till spring when I have money saved up to get it running.  Needs more than a good bath and a tune up, needs new paint and more than likely a new motor as well, cuz the guy that I had do the motor swap destroyed the old harness, so as you can see, it's a mess of cut and spliced wires under the hood.  It ran fine right before it was pulled from an '86 T-Bird, which was last summer, since then, nothing.
Post by: 5.0willgo on October 29, 2005, 06:12:11 PM
Quote from: venom_cat_86
I had a similar experience. When I swapped inthe H.O. in my car, I had no idea what I was doing so my dad found some guy to do it. Well he did a lousy job and screwed up a few things. I was looking into replacing my harness as well but the car is now running fine. I just had to go through and look for things he screwed up. It was long and frustrating but now the car runs better than ever. I did all of my other modifications myself so I even found some other things along the way that the "shadetree mechanic" screwed up.
Your motor may be fine but just look over that harness. Replace the entire thing if you have to because it could just be bad wiring. There's a whole list of stuff if the motor runs rough or whatever but if it won't even start or crank, that doesn't mean the motor's bad.
A little side note, once you save your money to fix it up watch so you don't throw it away on things you don't need. I've done quite a bit of this and if I could only go back...
Good luck with it
Post by: beaterjeep on October 29, 2005, 06:33:38 PM
Good luck with it
I've been trying to find another harness, preferably with all the sensors, but it's not an easy task, especially when the closest year T-Bird/Cougar in any junkyard or anywhere around here for that matter is all the newer stuff from say '90 and up.  I'm almost certain that it's the harness, but I'm no electrician by any means, and dont really know what goes where, and what plugs are missing off of the harness....... etc, etc.  All I know for sure is that the motor and computer are from an '86 bird, and the harness is from an '87 cougar, and that everything seems to be somewhat in order, just that no fuel is wanting to go through the injectors into the motor.  I pulled a couple plugs out just today in fact and put a couple drops of gas in each cylinder and put the plugs back in and it wanted to start, so........  I'm just at a "what do I do" stage.
Post by: 5.0willgo on October 29, 2005, 07:17:49 PM
All I know for sure is that the motor and computer are from an '86 bird, and the harness is from an '87 cougar.
That there may be your problem. I think you will need an 86 harness. The 87's were different in some places with connectors and such. I really don't know all the ins and outs on it but I'm sure if you made a new post about this issue, some others will be able to shed light on the problem.
I know what you mean about how difficult it is to find the right parts. There's one junkyard not 15 miles from me that must have about 30 fox bodied birds and cougars. Nobody else has any decent ones. Unfortunately the owner prices his stuff rediculously high and has ripped me off in the past. If it wasn't for the really big dogs guarding the place, I'd go get myself some five fingered dicounted items. Instead I'll just wait until he dies and it changes ownership. That shouldn't be too long from now.
