Has anyone tried changing the plastic cover on the front seat belt attached to the seat??
It looks like you could pull out the buckle if you remove the staples holding it in. I found a bergundy seatbelt, but my interior is grey. The plastic is in good shape on both.
Chris
You could do that...not a problem.
Also, see the thread started here: http://www.foxtbirdcougarforums.com/showthread.php?t=3611
