Technical => Misc Tech => Topic started by: Old man on September 16, 2005, 09:06:12 PM
Title: 86' Cougar
Post by: Old man on September 16, 2005, 09:06:12 PM
I have an 86 Cougar and can't get the ashtray to open without pulling it out, it is supposed to open when you push in on it. There is a spring or something that is supposed to help.
Can someone describe what I am looking for and where it might be located. The ashtray is at the bottom of the dash under heat controls.
Thanks,
Mike
Title: Re: 86' Cougar
Post by: vinnietbird on September 17, 2005, 08:35:22 PM
Perhaps the tracks that the ashtray roll on are mucked up.Just a guess.I haven't had one of those ashtrays in years now.
Post by: waferman on September 20, 2005, 03:48:20 PM
i took mine out and when i went to put it back in ....it did'nt work.....there are two ball bearings....one on each side of the guide rails...there big and easy to see...if one is missing the ashtray wont work right..hope this helps
Post by: Thunder Chicken on September 20, 2005, 06:33:03 PM
There's also a piece of spring steel that has to be in there correctly. It's been years since I had the ashtray out of a non-console car (and even then I wasn't interested in putting it back in since I was doing a console install) but I distinctly remember that spring thing...
