General => General Fox T-Bird/Cougar Discussion => Topic started by: CougarSE on September 01, 2005, 11:02:05 PM
Title: My cat is triping over its own paws.
Post by: CougarSE on September 01, 2005, 11:02:05 PM
My car has recently decided to want to buck and stumble when first taking off.  And just today it started to search for idle but go so high then so low it would die.  but if you put it in gear it is fine.  Hmm  Just wanted your opinions.  KOEO and KOER show code 33.  Egr code that has been there since I got the car.
Title: Re: My cat is triping over its own paws.
Post by: BEARMAX on September 02, 2005, 12:04:14 AM
Sound's Like The Tps
Post by: BEARMAX on September 02, 2005, 12:05:20 AM
Also Check The Idle Air Valve-
Post by: cougarcragar on September 02, 2005, 01:28:37 AM
Pull the IAC and try to clean it out with some carb cleaner. Free option that may help the problem.
Post by: Funky Cricket on September 02, 2005, 12:40:02 PM
:stupid:
yep. had to do that with mine.
Post by: 88turbo on September 02, 2005, 06:11:59 PM
my car does the same thing.  havent had time to do anything with it though
Post by: lostbrew on September 03, 2005, 10:21:50 AM
well that egr code has to do with some of the problem. what is the full code? egr stuck open or closed? if its closed then it would cause the symptoms you have described. in that case you would have to replace it or free it up some how. when i disconnedted my egr on my car when slowing down it bucked and when gowing slow it stalled out.
Post by: CougarSE on September 03, 2005, 06:42:30 PM
33  EGR Valve Opening Not Detected (Others)
This code has been there since I got the car almost a year ago and only now is it acting up.  As soon as its in gear it smooths out and doesn't search for idle.
IF the computer was opening and closing the egr vavle to see if the feedback sensor detected it I could see it acting this way.  The mil light is never set though.
Edit*  I've convinced myself its the feedback sensor But I don't understand why its now acting like this and wasn't before?
Post by: Tbird232ci on September 04, 2005, 12:19:16 AM
the EGR wont cause the problem unless its stuck open
my cars EGR is diabled, no vacume lines, and it still runs good
Post by: CougarSE on September 04, 2005, 11:54:43 AM
Shawn after playing with my car a little bit I think the problem is my base idle setting.  My multimeter is busted but when I buy a new one I will set it.  You seem to be the pro on this and from what I remeber set it just shy of one volt?
Post by: 5.0willgo on September 04, 2005, 01:20:19 PM
TPS at .98 volts.
Post by: Tbird232ci on September 04, 2005, 04:33:13 PM
TPS works best when set at about .94-.98
what you do, start the car, let it warm up, then disconnect your IAC, once the idle settles, set your idle to whatever is recommended for you car using the set screw on your throttle body, im not sure what the 5.0 is, but i think its like 750rpms, once thats done, go ahead and set your TPS to .94-.98, and that should be good
