Technical => Engine Tech => Topic started by: ONEpissedOFFstang on August 25, 2005, 05:01:57 PM
Title: M90 on a CARBED 5.0 PICS (finally here)
Post by: ONEpissedOFFstang on August 25, 2005, 05:01:57 PM
sorry it took so long guys.. Hope you enjoy... lotz of work still to be done (bodywork). Took awhile to get everything right , had to make a custom intake for the blower to fit on the edelbrock intake , then I had to make sure it cleared the distributer, , had to make a custom intake for the carb to sit on as well ,, it was said that I couldnt do this on a 5.0 from other forums.. But as you can see , hard work and patience pays off.. Hope you guys like it.. any questions let me know.. I wonder if I clean it all up ,do the body work , if this thing can make it in MM&FF.. LOL
Title: Re: M90 on a CARBED 5.0 PICS (finally here)
Post by: slamedcat on August 25, 2005, 05:23:21 PM
That slick looking.
But I have two words "Mad Max"
Post by: Haystack on August 25, 2005, 05:50:55 PM
that is f-ing bad. How long until it is functional? I kinda wanna see where this goes.
Post by: Ether947 on August 25, 2005, 05:52:56 PM
Wow, i'm impressed. Not many would have taken on the challange. :D
Post by: ONEpissedOFFstang on August 25, 2005, 06:04:33 PM
thanks guys, its only need the carb linkage hooked up and its all done.. I have the hilbourne blower scoop for it as well.. As soon as its started up , i'll get some sound clips too, maybe even a little burnout for yeah too.. :)
Post by: ONEpissedOFFstang on August 25, 2005, 06:05:18 PM
i have more photos aswell, if you guys want more.\
Post by: CougarCoupe88 on August 25, 2005, 07:38:01 PM
how big is ur hood gonna be man. i like it but that will not be streetable. with a hood on it. kinda sucks. but good job
Post by: Tbird232ci on August 25, 2005, 08:26:39 PM
i have to say, i honestly didnt think youd get it together, great job so far, cant wait to hear how it runs
Post by: nirvanagod on August 25, 2005, 09:58:43 PM
Quote from: ONEpissedOFFstang
Yeah a few good close ups would be killer. I'd like to see how that intake is setup.
Post by: 32VFoxBird on August 25, 2005, 10:00:50 PM
Quote from: nirvanagod
 :stupid:
Post by: nirvanagod on August 25, 2005, 10:24:31 PM
Quote from: 5ohbird
:stupid:
Hey now!!!!  :D  :hick:
Post by: ONEpissedOFFstang on August 26, 2005, 11:44:10 AM
Thanks guys, more pics coming up, and to cougarcoupe88 , thats the hood im using , its a 5 1/2 inch cowl and the hilbourne scoop goes on aswell.. TBIRD232ci , have some faith in me man ! LOL .
Post by: blownbirds on August 26, 2005, 11:48:47 AM
How do you put oil in the case with the unit upside down?  I take it you fill it before you put it on.
Post by: CougarSE on August 26, 2005, 12:49:50 PM
Hmm while I respect the fabrication I don't like how far it sits off the engine.  If you had built the lower intake ( i know a big pain in the ass)  You could have got it down low like a 3.8 does.  Those sharp bends look like they will hamper performance.
Post by: MexCougar on August 26, 2005, 01:32:24 PM
Congratulations, you shut some mouths....
 I like the Fabrication, good work man.
(EDIT) mmm, wait a moment, that means....can we build a Carbed 3.8 with the M90 ?
(http://teaca.iespana.es/almacen/Cougar.jpg)
Post by: ONEpissedOFFstang on August 26, 2005, 05:23:00 PM
I had to build the intake for the blower that high cougarSE , the 5.0 has a distributer in the front of the engine , not the back, so i had to clear it , also i needed it to beable to hold the weight of the blower.. and the oil was pre-filled, lol.. this was only the first attempt I made after I drew up the blueprints so, if it needs work, I can always tamper with it.. Hope you guys like.. Like I said , im going to get some sound clips and some more pics for you,(close-ups)
Post by: 1WLD BRD on August 27, 2005, 01:53:31 PM
the 3.8L has the distributor in the front as well, hence the DIS system on the SCed 3.8L's.  I don't like the looks of it, LOOKS homemade, but I am intrested in seeing if it will even run, and the longevity of using a blower as a draw through unit when it was never meant to be used that way.  You could have quite the ticking time bomb on your hands.
Get this beast running so we can see how all this works together.
Post by: greg wys on August 27, 2005, 11:09:28 PM
nice fab work, that looks like it was an engineering nitemare to design.  I hope it runs as good as it looks.  if not you have the most original setup ever!
Post by: Funky Cricket on August 29, 2005, 01:49:26 PM
does it run, do you have problems with your a/f ratio's with the fuel coming it pre-compression? do you keep proper atomization, or do you get puddling?
