Technical => Misc Tech => Topic started by: GrannysBird on November 11, 2004, 12:01:06 PM
Title: O rings on fuel injectors
Post by: GrannysBird on November 11, 2004, 12:01:06 PM
Ok i just got finished painting my lower intake manifold on my 5.0 and i figured while the fuel rail and fuel injectors were out i might as well replace the o rings on the injectors, but how do i get the lower o ring on the bottom (part that sits in the manifold) off? it doesn't want to slide off b/c of that nasty lip, so should i just try cutting it off?
Tony
Title: Re: O rings on fuel injectors
Post by: jcassity on November 11, 2004, 07:05:30 PM
replace the screen filters on the top as well.
Post by: Ifixyawata on November 11, 2004, 09:38:53 PM
The o-ring shouldn't be sitting in the manifold.  It should have come off with the injector.  If you wanna go all out just get a service kit that includes 2-orings and a cap for each injector.  You'll need 8 kits in total.
Post by: GrannysBird on November 11, 2004, 10:12:49 PM
 i need filters too?.......... :shoothead
 fuel injection!
Post by: MasterBlaster on November 12, 2004, 08:56:02 AM
The o-ring is rubber, so it should stretch a bit. Try pinching it with two fingers and "squooshing" it to the side; that may create enough of a bulge to slip a toothpick or something under it. If you have a seal pick (looks like an ice pick with the tip bent 90 degrees), you could hook it out of the groove. Or use something softer than the surrounding metal, like a sharpened popsicle stick. If you insist on trying to cut it, be very careful, as a scratch on the sealing surface in the groove could create a leak that can't be fixed.
Post by: jcassity on November 12, 2004, 06:25:54 PM
no you actually dont need the filters,, you actually need to get rid of them once and for all.  I dont know what the "cap" part is mentioned before but if it doesnt come with new screen filters,, your waisting you money on the kits.  Bying plain jane rubber orings of the highest quality will not run you more than 1 doallar at worst case.
You can extract your old screens,, clean em , reshape em and reinstall em.
mmm,, maybe the caps are the bottom of the injectors,, correct?? :dunno:
Post by: Ifixyawata on November 12, 2004, 08:43:03 PM
Yeah, jcassity, the caps I refer to kinda slide onto the bottom of the injectors.  I'm hoping I won't have regretted not replacing mine on the Grand Marquis.
Post by: GrannysBird on November 14, 2004, 09:38:59 PM
just got the buggers off with a dental pick things were a royal pain in the ass! i just hooked the pick behind the ring the pulled it up and out pushing it over the top of the cap with me fingers. so yippee! done
