Technical => Suspension/Steering => Topic started by: cougrrr302 on August 17, 2005, 12:36:18 AM
Title: Converting to 5 lug(common i know)
Post by: cougrrr302 on August 17, 2005, 12:36:18 AM
If i take the rear end and from hub assembly out of an 85 ranger can i swap it over to my 84 cougar. There will probably be a little complication i would expect. But would this be a way to do it?
Title: Re: Converting to 5 lug(common i know)
Post by: Thunder Chicken on August 17, 2005, 12:31:44 PM
The rear end will not bolt in - the Ranger uses leaf springs while your Cougar has a four-link setup with coils. I believe you can use one of the axles (the axles are two different lengths on Rangers) but the whole thing is a no-go.
Post by: cougrrr302 on August 17, 2005, 11:43:24 PM
Post by: NorCalAeroCoupe on August 18, 2005, 09:37:26 AM
I think from now on....all rear end swap questions should be redirected to "I'm gay as hell"......he should be able to provide some interesting feedback....... ;-)
Post by: 88FoxBird on August 18, 2005, 10:31:21 AM
What about the front? Would they swap over?
Post by: SLEEPER T-BIRD 87 on August 18, 2005, 03:12:31 PM
for the front you need to use 89-91 ford aerostar front rotors  have the diameter cut down .120 thou "any brake shop can do this on any brake lathe"
for the rear i would suggest having them redrilled for the 5 on 4.5 bolt cirlce 1any competent machine shop can do this also
than run ranger drums > 9 inch drums
or have the factory ones redrilled >10 inch drum
Post by: EricCoolCats on August 18, 2005, 04:41:54 PM
Stock 10" 5-lug rotors here: http://www.completebrakeservice.com/
No mods necessary...bolt-on...around $130US shipped to your door (and that includes seals and bearings from what people have reported).
