Technical => Engine Tech => Topic started by: Roadmister on November 12, 2025, 06:09:34 PM
Title: 2.3 Turbo Front Main Seal
Post by: Roadmister on November 12, 2025, 06:09:34 PM
Fixing an Oil Leak at Front Crankshaft Seal. Not the Original motor. How do Identify the Block and what replacement seal is needed?
Title: Re: 2.3 Turbo Front Main Seal
Post by: Chuck W on November 12, 2025, 10:55:01 PM
All of the 83-88 2.3T's use the same front main seal.
Post by: Roadmister on November 16, 2025, 04:55:22 PM
Thanks Chuck, So this an 83 to 88 era motor?
It was a bear to get this gear off. couple hours, a torch, and it ate two pullers.
Post by: Chuck W on November 16, 2025, 06:40:53 PM
It's hard to say for sure what year w/o having it in front of me.
It's got the earlier AL valve cover and the square intake and a d T3. I see brown-top injectors, so it *might* be an 86 TC or XR4Ti motor. But people swap those things around at will, so it's hard to be sure. That PS pump is not found on the 2.3Ts.
Regardless of any of that, all of the Lima 2.3's, NA or Turbo with the single-plug heads, use the same front main.
