Technical => Engine Tech => Topic started by: sum_weirdo on July 31, 2005, 03:01:57 PM
Title: 0 oil pressure....
Post by: sum_weirdo on July 31, 2005, 03:01:57 PM
So I finally got around to checking the oil pressure.  Something I should have done ages ago I grant you but I'm still new at this.  So with my trusty $10 oil gauge plugged in I recorded the initial oil pressure at about 45 PSI (it's got 30W oil).  10 minutes in oil pressure was around 12.  Then I put the car in gear and it dropped like a rock...might be a few PSI since the gauge goes in increments of 25 but still it's pretty down there.  I'm mostly just venting at this point because it's obvious I need a new engine in there.  Oh well.  I'll manage it.
Title: Re: 0 oil pressure....
Post by: SLEEPER T-BIRD 87 on July 31, 2005, 03:38:14 PM
id put some 20w 50 in it and if i doesnt knock i would drive it till it started knocking
and get a good oil pressure gauge one that doesnt read in 25 pnd increments
Post by: V8Demon on August 01, 2005, 12:01:52 PM
Very important to get a good guage and to make sure it reads correctly.  My brand new Snap-On guage is going back because it reads low....Tested the pressure iwth TWO OTHER GUAGES and they read identical while my brand new one read 7 PSI low on all accounts.
