Technical => Engine Swapping => Topic started by: 88cat on July 28, 2005, 11:14:08 PM
Title: 460 in cougar help
Post by: 88cat on July 28, 2005, 11:14:08 PM
Hey guys who have done a 460 swap in a fox chassis I want to put a 460 in my cougar with the least amount of money. I know I will need k member, oil pan and what else? Will I absolutelly need swap headers can the stock manifolds work? Also can I keep my power brakes without going to manual brakes? thanks guys lmk the engine is going to be out of a 70's lincoln.
Title: Re: 460 in cougar help
Post by: Ifixyawata on July 29, 2005, 12:47:02 AM
Need different headers, no question about it.
Post by: SLEEPER T-BIRD 87 on July 29, 2005, 09:20:31 PM
i belive you can use stock manifolds i have seen a few mustangs with them
Post by: cougarman on July 29, 2005, 10:36:05 PM
ya you can use the manifolds, mustang headers will need a little tweeking what year is your cougar? 87-88 will need a k-member swap to work right i have an 87 bird with a 460 if you want some pics, i have power brakes i used the small mustang booster the only probs i have had is the headers, swaybar and hood clearance
Post by: 88cat on July 30, 2005, 04:17:53 PM
My cougar is a 88 and i plan to go with tubular k member I would like to use the stock manifolds for now, also I would love some pics to see more less what im into thanks guys.
Post by: 88cat on July 30, 2005, 04:22:04 PM
Another thing I forgot to ask is that will I also need a swap oil pan with tubular k member? I belive in the lincoln its a front sump oil pan could i maybe massage the oil pan to make it fit? thanks guys lmk.
Post by: SLEEPER T-BIRD 87 on July 30, 2005, 08:10:59 PM
Quote from: 88cat
you can ussally search e-bay i got my canton swap pan off there
they can be had pretty cheap
Post by: fordguy on August 04, 2005, 11:17:15 AM
you can get a 460 truck pan off a late 80's f series 460, that is what the fms pan kit is. power brakes ,yes. there is a pic of my old bird in another thread here, biggest engine or something.
Post by: 88cat on August 12, 2005, 01:04:05 PM
Hey guys with 460 all of you are using the swap 460 mounts correct? thanks guys lmk
Post by: SLEEPER T-BIRD 87 on August 12, 2005, 08:22:50 PM
Quote from: 88cat
i will be but i am also using a tubular mustang k member
Post by: SirChirpAlot on August 21, 2005, 07:50:34 PM
I'm looking at going with 460 for my TC
I hate pondering idea's
Post by: SLEEPER T-BIRD 87 on August 29, 2005, 01:03:10 AM
Quote from: SirChirpAlot
here ya go this is what it looks like to help ya along :D
Post by: SirChirpAlot on August 29, 2005, 12:16:04 PM
Looks good i helped my buddy put 460 into his stang 2 years ago.
What headers are u using?
Post by: SLEEPER T-BIRD 87 on August 29, 2005, 07:26:49 PM
hooker super comps they fit real well really
Post by: SirChirpAlot on September 19, 2005, 05:03:05 AM
I think he had ford motorsport 460 swap kit not to sure.
Still pondering 460 idea. Will not do anything till i have the TC at the shop to start anything.  Plan frist get parts build car pay VISA.
I have 460 botom end with 440 rods and forged pistons already, Need a set of AL cobra jet heads. I have a roller cam and lifter kit from a buddy. C6 tranny and 9inch already.  Slowly finding parts for it.  I need to find a tube K member and front sus then get laderbar kit
Post by: thomased@charter.net on September 27, 2005, 12:50:52 AM
So where do you get all the items to swap a 429/460 into a 88 cougar??  Is there a kit or do you have to buy from all over to get parts? Is the k member like in a chrysler car to swap it .....HELP :toilet:
Post by: SLEEPER T-BIRD 87 on September 27, 2005, 01:03:27 AM
Quote from: thomased@charter.net
get a mustang k member
use mustang swap mounts
use mustang swap pan
use mustang swap headers
all can be purchsed as a kit or bought seperate
e-bay usally has some good deals on this stuff
Post by: thomased@charter.net on September 27, 2005, 01:10:44 AM
What year mustang parts do I use?? And will a xr7 rear hold up on the street...what is the bolt pattern I have a set of 17" 4 on 100mm white 8 spoke wheels ..will they fit??
Thanks a ton
Ed
Post by: SLEEPER T-BIRD 87 on September 27, 2005, 01:16:29 AM
Thanks a ton
Ed
79-93 will work
not sure on the wheel i beleive the pattern is 4 on 4.5
Post by: thomased@charter.net on September 27, 2005, 01:19:54 AM
Thanks for the help
ED
