Here you go straight from http://www.mass-air.com/Products.htm
Mass-Air Harnesses
- IST has converted more cars to Mass-Air than anyone!! Over 20,000 harnesses and computer kits sold to date, with no end in sight!! If you want to convert a Speed Density engine to a Mass-Air engine, IST’s LOW-COST conversion harness is the answer. All harnesses designed for speed density Mustang, Thunderbird, Cougar, Mark VII, Crown Victoria, Grand Marquis, & Town Car. Will not work on trucks, see truck conversion kits. Why convert to Mass-Air in the first place?? Simple, on a totally stock car engine, you will generally pick up 2 - 3 MPG, along with much crisper throttle response. On modified engines, it's mandatory, since the stock Speed Density computer has a very small "window" of adjustment built in to handle those changes. Even if you have modified your stock engine and it still seems to run OK, you still are not getting the maximum benefit from all those expensive aftermarket parts you put on. Plus, you have the added benefit of cleaner emissions, since most Speed Density systems tend to run on the rich side. This true OEM-style and quality kit allows you to custom tailor the harness to the exact length you need. Plus you'll find competent, friendly, and FREE technical support is provided for all of our products. We'll work with you to try and solve any problem you may encounter!!
Part Number CH-8611-F, for EEC-IV connectors (4 terminal oval)…….......................................$34.95
If the engine is going to be stock it will run just fine(actually stronger) on '87-'88 Stang speed densety computer, and would require NO wiring changes.
