I purchaced a 1987 Cougar 5.0L . It came with single Exhaust,..I want to put on duals...Anybody done this on your 87 88 Cougar.??
Throw some stock Fox Mustang headers on it, a Fox Mustang H Pipe, then have the rest added at the ler shop. The H-Pipe and headers are a simple bolt on, but the mid pipes and tail pipes are different from a Mustang.
+1... Stock mustang headers can be found cheap.
Or, if you're only interested in the look, you can get the 88 v8 cat-back, for what is essentially a single exhaust with 2 lers and tails.
Thanks......I want full duals....will see what I can find next week....
It bears mentioning that the HO headers and H-Pipe setup will require HO oxygen sensors, or 8 inch(?) extensions; as in that setup, the O2s are in the H-Pipe and not the manifolds/headers.
You can also lengthen the car's oxygen sensor harness (that's what I did). Be sure to solder the wires and not use a crimp connector.
DO NOT lengthen the oxygen sensor wires themselves. You'll ruin the oxygen sensor that way.
the o2 sensors need 600+ degrees to start making thier own millivolt signal,, how can they do that if they are so far down stream
is it really that hot on the hpipe?
Late 86 on the o2 sensors are heated. The 4.6 mustangs have six catalytic converters and pre and post o2 sensors, the post o2's are near the end of the h-pipe.
