pulling apart engine for new heads and and an upper intake and i found a wire severed on the fuel injector harness any clue what its for?
http://i.imgur.com/ZtdESYW.jpg
Possibly the oxygen sensor ground wire?
That is my guess as well. I remember it being orange.
perfect so i guess ill just ground it to the block?
Check pin 49 for continuity before grounding.
http://www.veryuseful.com/mustang/tech/engine/images/88-91_5.0_EEC_Wiring_Diagram.gif
Thanks guys its the ground wire
Redundant and not needed on the CougarBird harness.
http://www.foxtbirdcougarforums.com/showthread.php?21560-White-10-pin-connector
