Technical => Suspension/Steering => Topic started by: GDawg148 on April 08, 2016, 06:40:29 PM
Title: Going with Viking coilovers.. what else do I need?
Post by: GDawg148 on April 08, 2016, 06:40:29 PM
Hey guys, couple things:
 I have a friend who is going to give me a deal on some coilovers made by Viking Performance and they are made for a fox mustang.  These should work, correct?
I also plan to go with Maximum Motorsports caster camber plates, however; will fox mustang caster camber plates work? (more specifically UPR caster camber plates)
I'm also in need of new struts.  What struts do you recommend for an 88 Bird with coilovers?
Thanks guys.. us american muscle guys no nothing about suspension, right?  Straight lines? :burnout:
Post by: thunderjet302 on April 08, 2016, 09:15:36 PM
You'll have to use Thunderbird cast/camber plates as Mustang ones won't bolt in.
Post by: GDawg148 on April 10, 2016, 09:17:14 PM
From what I'm reading, I can use 94-98 Mustang struts.  What about brake spindles?  Will the stock ones clear?  I've been reading I may need TC spindles.
