Hey guys,
I have a JET PCM performance chip for the stock T-Bird/Cougar ECU. The PO 'donated' the car to the local wrecking yard but gave me first dibs at parts. He didn't know it was installed. It is part # 78801. Here is the link from Summit. http://www.summitracing.com/parts/JET-78801/
I can't tell you what kind of performance gains these chips provide -- I don't have any experience with them, but maybe it will get you a bit out of the 155 HP blues with very little work. It just installs on the J3 connector of the stock ECU. I think you have to clean the plastic off of the contacts first to make sure it gets a good electrical connection (I only know this because I looked at the SCT chip install video). On Summit it sells for $250 -- I'll let this go for $100.
No takers. taking it down to $75.
Bump down to $50
