Technical => Misc Tech => Topic started by: Alan87bird on October 10, 2015, 08:05:35 AM
Title: Rough Engine Idle with Air Conditioner Running
Post by: Alan87bird on October 10, 2015, 08:05:35 AM
Has anyone dealt with the problem of the engine idling rather rough when the air conditioner is running.  Once I pull off from a stop, she purrs like a kitten.  At idle it pulses.
Post by: Masejoer on October 10, 2015, 11:11:53 AM
Quote from: Alan87bird;451705
The idle is supposed to raise when the a/c is engaged. Does it go up, or does it drop from normal idle? Could be that the idle-air controller/bypass is maxed out and can't allow in more air, or not working correctly. It's also possible something is going on with the a/c compressor?
Which engine does your car have?
Post by: Alan87bird on October 11, 2015, 08:56:24 PM
The engine is the V6.  And, yes it does idle lower when the compressor kicks in.
Post by: softtouch on October 12, 2015, 12:29:23 AM
Take the air cleaner off and verify that the idle speed control motor plunger moves.
Check the ISP motor adjustment.
