General => Lounge => Topic started by: vinnietbird on June 01, 2015, 07:45:20 AM
Title: Fuel pump swap.....
Post by: vinnietbird on June 01, 2015, 07:45:20 AM
No big news, we all know what a fuel pump swap is. The cool part.....12 minutes from start to finish with a full tank. I am SO glad I have the access panel in the trunk!!!!
(http://i216.photobucket.com/albums/cc205/Vinnietbird/10151864_10203588103809605_199342178_n.jpg) (http://s216.photobucket.com/user/Vinnietbird/media/10151864_10203588103809605_199342178_n.jpg.html)
Post by: mercury-man on June 01, 2015, 03:30:16 PM
Nice V-man
Post by: Haystack on June 01, 2015, 04:11:26 PM
I am washing my clothes for the third time and they still smell like gas.
I hate you right now ;)
Post by: V8Demon on June 01, 2015, 04:23:32 PM
Head and Shoulders shampoo in the washing machine will get rid of the smell.  Did it for years when I worked on jets.....
Post by: daminc on June 01, 2015, 04:35:19 PM
Quote from: V8Demon;448525
does it work as a hand soap the same way?
Post by: V8Demon on June 01, 2015, 05:11:22 PM
Pretty much.  Takes a few times on your hands, but faster than regular soap by far....
Post by: FOX-XR7 on June 01, 2015, 07:45:48 PM
That's awesome . Was that access hole there, or was it a Vinnie touch?
Post by: 1BadBird on June 01, 2015, 07:57:12 PM
That would be a Vinnie touch
Post by: FOX-XR7 on June 01, 2015, 08:26:47 PM
Haha that's awesome . I guess it's too good to be true if that were factory.
Post by: thunderjet302 on June 01, 2015, 09:15:26 PM
How often are you changing that pump? I only had to change my pump when I did the HO swap (knock on wood). My Mark VII is still running it's factory pump (knock on wood).
Post by: daminc on June 01, 2015, 10:39:55 PM
I think he takes it out just to polish it up...lol
Post by: Haystack on June 02, 2015, 12:23:25 AM
Lol, maybe vinnie swaps his pumps like he does upper intakes ;).
My factory pump lasted 316k miles and 29 years. My replacement lasted less then 24 hours and 75 miles. My timing wasn't off too bad, car had no power because it was fuel starved. Pump was putting out 15psi.
I have sheet metal screws and black caulking, now i need tin snips. I promise you that will be my next purchase.
Post by: vinnietbird on June 02, 2015, 07:50:46 AM
I swapped my pump when mine died, and I had a full tank of gas. Hated dropping the tank. But, I dealt with it. The pump I bought was from Autozone. It died about a month later, so, the access panel was fabbed. The panel it self is made from sturdy sheet steel, and the gasket is simply cork/rubber sheet cut to fit the panel. I coated each side of the cork gasket with black rtv, and stuck it to the panel, and allowed the other side to simply air dry. Then when I install it, it seals to the trunk floor without sticking to it. 9 short self tapping metal screws hold it in place easily, and once the carpet is back down, nobody would ever know. Some hate the idea of cutting the hole, but, it's very functional. We make a  ton of mods to everything else, so why not? If you do it, you'll thank me one day if your quite a ways from home and your pump dies. I can swap the pump anywhere, in a few minutes, even wearing nice clothes if I was taking Gayle out on a date.
Post by: jcassity on June 06, 2015, 01:39:00 PM
on the bottom of the car we are adding a long rubber flap to the body just forward of the tank.  that will keep any and all debris from getting on top of the tank.
we will use plastic buttons to hold it on the car.
Post by: vinnietbird on June 06, 2015, 04:49:00 PM
Good thinking. I need to add one of those.
Post by: DSGcoupe on April 10, 2016, 11:53:44 PM
Sorry for the thread resurrection, but where exactly did you cut the access hole in the trunk?
Post by: Haystack on April 11, 2016, 02:24:07 AM
Floor of the trunk, its under the "home plate " shaped bubble. You can clearly see the shape in Vinnie's pic, and once you pull up the carpet it will be obvious.
Post by: vinnietbird on April 11, 2016, 07:34:38 AM
The left side of the picture is the rear of the car. The bottom is the passenger side.
Post by: DSGcoupe on April 11, 2016, 11:18:20 PM
Thank you gentlemen!
Post by: vinnietbird on April 12, 2016, 04:27:04 PM
No problem
