Technical => Suspension/Steering => Topic started by: Nate on July 12, 2005, 11:26:33 PM
Title: advice needed bump steer kit
Post by: Nate on July 12, 2005, 11:26:33 PM
ok,  im like this close to makeing it to CJ with my car, and i need to get a bumpsteer kit to make up the difference in length of my outer tie rods. their  a bit to short, so i found this kit on ebay and if i get the later modle mustang ones, (94-04)  they are the longest i found.... only thing is their a different thread.  think i should get them, and retap the bumpsteer kit aluminum sleeve for my inners, or go with the maximum motorsport kit thats 1/10th of an inch shorter in length and double the price. im not sure if the inner diameter of the sleve is the same eather.
Title: Re: advice needed bump steer kit
Post by: Chuck W on July 12, 2005, 11:38:04 PM
You could swap inner (and outer) tie rods from an SN-95 onto your rack.
Do you "need" the bumpsteer kit, or are you just looking to make something longer?
I would not "retap" the kit parts....you'll just wind up with nice anodized paper-weights
Post by: Nate on July 12, 2005, 11:41:16 PM
yeah, well i lowered the car about an inch and a half... i think its still up in the air. but im leaning twards the MM kit sence im sure its far better quality and i can use the fox type threads and only scrafice the .1"  pluss i just replaced the entire suspension with new tubular stuff, or other aftermarket things so i want to cover all the baises. another thing is i didnt want to change the inner tierods, dont have the tool to do it, and they were just replaced along with the new rack about 2 years ago. tomorrow im gonna take some final measurments and try to make a desision.
Post by: cougarman on July 13, 2005, 08:48:19 AM
why dont you use the mustang kit for 87-93 mustangs they use the same tie rods as a t-bird-cougar and actually 91 or newer mustang have more bumpsteer built into them stock also
Post by: Bob on July 13, 2005, 04:07:34 PM
hey nate got any pics of your new setup?
