Marketplace => T-Bird/Cougar Parts & Cars WANTED => Topic started by: GDawg148 on December 27, 2014, 03:39:13 PM
Title: Want to buy A9P Mustang computer for MAF conversion
Post by: GDawg148 on December 27, 2014, 03:39:13 PM
Looking for an A9P computer from a Mustang with MAF.  Doing a MAF conversion on my Thunderbird.  Let me know what you got!
Post by: TheFoeYouKnow on December 27, 2014, 09:59:02 PM
http://shop.fiveologyracing.com/1986-88-FORD-MUSTANG-50L-MASS-AIR-CONVERSION-KIT-MMAK.htm
This is where I got mine.
Post by: GDawg148 on December 28, 2014, 11:48:48 AM
Quote from: TheFoeYouKnow;442037
I actually have everything but the harness and computer itself.
Post by: Aerocoupe on December 28, 2014, 11:56:13 AM
Did you post up in the Marketplace for this?  Also, check the Mustang sites as that is where you will have a better shot at locating one.
Darren
Post by: Lightningbird on December 28, 2014, 05:54:54 PM
I have a A9P but you must buy the chip, calibrated MAF and 24lb injectors with it. They all work together. I will make you a screaming deal since I do not need it any longer and you are a fourm member and fellow T-Bird lover. I even have the factory bracket, bolts and elbow.
Post by: GDawg148 on December 29, 2014, 12:24:05 AM
Quote from: Lightningbird;442071
PM sent
Title: Want to buy A9P mustang computer
Post by: GDawg148 on December 29, 2014, 12:31:34 AM
I want to buy an A9P mustang computer.  Doing a MAF conversion on my Thunderbird.  Lemme know what you got!  Also need the harness.
Post by: thunderjet302 on December 29, 2014, 02:10:04 PM
For the MAF harness plug just go to the junkyard and take the MAF plug and as much wiring as you can from any 88-95 MAF equipped Ford. They all use the same plug. Then go into the EEC-IV plug at the computer and remove four pins from the harness. This is the same thing as the MAF conversion harness that most vendors sell. I did this when I converted my Thunderbird to MAF seven years ago. It cost me less than $15 for the plug and EEC-IV pins at the junkyard. Quite a bit of savings over the $50+ that most vendors sell the harness for.
