Technical => Misc Tech => Topic started by: Haystack on December 24, 2014, 07:48:43 PM
Title: blower motor
Post by: Haystack on December 24, 2014, 07:48:43 PM
Is there a trick to this? Or is it as bad or worse then a heater core? Guy at autozone said you just pull the glove box, but there ain't no way it could even fit.
Title: blower motor
Post by: Beau on December 24, 2014, 11:28:06 PM
Pull the dash, then the whole heater box. The rest is self explanatory.
Title: blower motor
Post by: hwy73 on December 25, 2014, 08:29:42 PM
On an A/C car, the blower motor does go in from the firewall side of the heater box. The blower housing with the air recirculation door, comes out seperately from the rest of the heater box.  Working through the glove box opening, it can be dropped down under the dash for removal.
Title: blower motor
Post by: Haystack on December 26, 2014, 05:00:26 PM
Hitting this now, hopefully I'll have heat again. The 60's temp wise have been a blessing, but snow and a 3hr daily round trip are getting old.
Title: blower motor
Post by: Haystack on December 26, 2014, 08:04:18 PM
The squirrel cage was discontinued. I carefully removed mine, despite the cracks in it. Fired up the motor, it turned fine, started the car, hit the high setting on the fan, and was rewarded with a Big Bang as the squirrel cage exploded
Title: blower motor
Post by: Beau on December 26, 2014, 10:08:27 PM
So you need a squirrel cage..?
I've got 2 or 3 heater boxes I'm about to throw in the ditch...let me know whatya need. Yours for shipping costs.
Title: blower motor
Post by: Haystack on December 27, 2014, 12:20:23 PM
On the way to the junkyard now, but id throw ya some money for one as a back up. Ill send ya a pm when i get back.
Title: blower motor
Post by: jcassity on December 29, 2014, 10:13:06 PM
yes, please don't toss the  blower motors or the resistors.....
count me in on some $ for a spare resistor and blower...
the box I guess you could toss,
manual systems are more common, my 20th is climate control.
the climate control systems are a tad different , and if you can tell the difference, that would be nice.
Title: blower motor
Post by: Haystack on December 29, 2014, 10:46:41 PM
Blower motor and box looked identical to me. I pulled a eatc blower motor off an 87 bird for the squirrel cage, then they wanted to charge me for the motor too, so i ended up just swapping in the junkyard blower motor. I took the plastic sides off the blower motor and the junkyard, but i believe they are identical.
Title: blower motor
Post by: Haystack on December 29, 2014, 11:13:05 PM
I lied. The blend door actuated or whatever its called, it is slightly different. It looked like just a different bracket bolted to the same blower motor box though.
Title: blower motor
Post by: jcassity on December 30, 2014, 12:25:59 AM
they are a bitch to drop but ive had to drop my blower out and it always ended up coming out of the bottom, didn't have to pull the dash.
there's absolutely zero room to even get to the rear fasteners, I think there is a wire harness around the back part of the motor itself that shares a mounting bolt.,,, sux to high heaven to simply drop out the bottom but I know I did it years ago in my white coug.
somehow I seemed to manage getting the rear mount hardware out though,, perhaps I didn't put the last mount bolt though..
Title: blower motor
Post by: Haystack on December 30, 2014, 03:09:20 AM
I pulled the whole blower motor blend door box. One bolt goes on the top right corner, two bolts from underneath, and one bolt goes right on the left side where the heater core opening goes through. Just dropping the glove box down no need to unbolt it. In 10-15 minutes, i could have the blower motor swapped. Bit of a bitch to put back in, not slot of wiggle room.
Title: blower motor
Post by: JeremyB on December 30, 2014, 10:41:07 AM
Yeah, not a bad job. My old Cougar had been in an accident before I got it. Required pulling the dash because that little bit of wiggle room to remove the blower housing was gone. :toilet:
