Does anyone have the bolts that hold the back to the bottom? I need the bolts for both seats. NO RUSH.
I'll look in the am.
Shweeeeeet. Thanks.
I only need them for one seat. Not two. I found some bolts this morning.
I looked in storage container and no luck. I should be in garage later today. I'll keep you posted
No hurry at all, and no pressure. Thanks a lot.
Getting my little world ready for winter. I'll be back out there Tuesday. Then I'll have time to clean the bench and get to the bolt pile.
Thanks.
Can you not just get bolts at the Ford Dealer ? I need one as well and am thinking they would have them, try them in your area
The ford dealer had all my signal lamps and I mean the old style ones - I bought them all - 8 of them they had left
you'd be surprised what the dealers can find
they had 1 license plate front holder that I got shipped from Montreal it was 80$ but worth it since all the others I could find were all cracked
Our ocal Ford dealer can get nothing. Believe me, I have tried many times over the years. As far as the bolts, not an emergency, not a big deal.
Haven't forgotten you. Got some heat in the garage just gonna run a duck to my work bench. Then the clean up will start. Been unseasonably cold around here. Could be worse. Could be in buffalo.
I appreciate you, and like I said, NO HURRY at all.
I have a 1986 mercury cougar and the seat switch doesn't work. I am not sure if i just need to get a just a Seat Motor or a Reclining Seat Motor. Does anyone know?
Probably the switch. Hard to say. Ask up in the tech area for better results.
front seat Hinge bolts,, correct?
I'm good. This was from two or three years ago.
