Technical => Electrical Tech => Topic started by: TheCowboyKiller on November 12, 2014, 12:16:15 PM
Title: Power Door Lock Problem
Post by: TheCowboyKiller on November 12, 2014, 12:16:15 PM
Hey guys,
I have a 1987 LX t-bird with power everything. The unlock button works but the lock button doesn't. Any idea what could be causing this problem? It's happening on both the driver side and passenger side.
Thanks!
Post by: softtouch on November 12, 2014, 01:43:48 PM
There are two relays under the passengers seat. Check if one of them has come unplugged. If not, try swapping the relays and see if the problem changes.
Post by: kylesburrell on November 12, 2014, 03:53:40 PM
the relays for the door locks are under the passenger seat? that might explain why my door locks dont work at all. neither does my keyless entry pad
Post by: softtouch on November 13, 2014, 05:31:42 PM
Quote from: kylesburrell;440523
Keyless entry cars do not have the lock relays. Locks are controlled by the keyless entry module.
