Technical => Electrical Tech => Topic started by: vinnietbird on November 01, 2014, 06:29:51 PM
Title: I need a quick answer...
Post by: vinnietbird on November 01, 2014, 06:29:51 PM
On an '88 Thunderbird, there should be two plugs for the OBD 1 testing. The big plug is easy, what color is the single wire?
Post by: softtouch on November 01, 2014, 07:14:48 PM
EVTM says W/R for STI wire.
Post by: jandmmustangs on November 01, 2014, 07:39:47 PM
^ this
Post by: Trinom on November 02, 2014, 04:25:59 AM
STI connector has light grey plastic.
Post by: Masejoer on November 02, 2014, 01:30:22 PM
See attached picture.
Post by: thunderjet302 on November 02, 2014, 05:16:14 PM
Yep white with red stripe. Mine still has the factory single terminal connector as well.
Post by: vinnietbird on November 02, 2014, 06:25:27 PM
My gray plastic piece is missing, but, I can locate that gray piece and snap my wire into it. I have a holder for those plugs to snap into when not in use. I think I'll install that next weekend. Just have to drill a small hole and it snaps right in. Then the plugs into it.
Post by: vinnietbird on November 08, 2014, 08:39:06 AM
Seek.....can you post a big clear pic of that plug from the back side as well?
Post by: vinnietbird on November 08, 2014, 09:03:22 AM
Seek....yours is different than mine. Mine has one more wire than yours.
Thunderjet, can you post a pic of yours front and back?
