Technical => Engine Tech => Topic started by: jcassity on October 05, 2014, 11:44:53 AM
Title: distributor question
Post by: jcassity on October 05, 2014, 11:44:53 AM
the piece of the dizzy that is under the rotor button, the round finned thing that passes through the stator............
when the stator magnetic field is not obstructed , does that determine the "ON" state or is the open window considered to the computer "Off"
if the answer is the open window determines "ON" , then lets assume someone had .001 or less aggressive but .0005 metal removed so the opening is this much wider?
what would happen,, injectors stay on a tad longer ??
Post by: Haystack on October 05, 2014, 12:35:15 PM
It would just signal the computer to fire a bit earlier. Not any different then slightly increasing timing. The computer dictates fuel. The pip just dictates when the #1 is fired, following the rest sequentially.
Post by: jcassity on October 05, 2014, 01:14:19 PM
Quote from: Haystack;438701
I thought the opening "width" was engineered and equal for a reason (excluding cyl 1) so the time the pulse is modulated is proportional to the opening....??
Post by: Haystack on October 05, 2014, 01:51:19 PM
Either way, the computer would still dictate the actual fuel flow. Even if you did increase when the injector opened, the computer would compensate.
Post by: thunderjet302 on October 05, 2014, 10:30:45 PM
Quote from: jcassity;438702
It's different so the pip can signal the computer when cylinder #1 is coming up for the sequential injection. Changing it will not make a difference or increase performance. If it did people would have done it already. The only way to increase the injector pulse rate is to change it in the computer.
