Technical => Electrical Tech => Topic started by: sposey7 on August 24, 2014, 12:33:51 PM
Title: Door ajar light stays on, but dome light is off.....
Post by: sposey7 on August 24, 2014, 12:33:51 PM
Hey guys.
On my '88 T-bird Sport, the "door ajar" light stays on, but the dome light goes off when the door is shut.  I wouldn't think the pin-switch(es) would be bad if one work and the other doesn't.
Any ideas?
Thanks in advance,
Pose
Post by: sposey7 on August 24, 2014, 09:22:05 PM
I sprayed some wd-40 into the pin-switches in the door jambs and worked the switches several times.  I think that did the trick.
Post by: softtouch on August 24, 2014, 11:21:24 PM
The door jamb switch is for the dome light.
The door ajar switches are on the door latches inside the doors.
If it comes back try spraying the WD-40 into the door latches.
Post by: White85GS on August 24, 2014, 11:36:31 PM
Very, very, VERY common problem on later Fords, pretty much all cars have the switch attached to the latch nowadays.
Post by: sposey7 on January 13, 2015, 04:37:59 PM
Thanks for the advice.  I bought new pin switches and the ajar light started working correctly.  Funny thing is, they're still in the box!!  I did hose down the latches really well, which I think did the trick.
