I obtained this harness from a junker at a yard. It is intact EXCEPT (I believe) for the leads to the license plate light, and the fact I cut it at a location somewhere upward in the trunk. See pic. The harness came from an '87 but will work with a '88. There is a difference with the lights. This harness supports Bayonet type bulbs---The insert and turn type which have a metal base and were the standard US auto bulb for eons! Whereas my '88 has the plastic base bulbs which work with a metal clip for retention (PIA). There are also several lamps which are push in types which means this harness has 2 types of lamps (as both would). If you need more details, I can get more pics. You are also welcome to the handful of clear and amber bulbs which came with the harness--I cannot guarantee their quality (untested). Write for details and agreement on cost incl shipping. Davenport Iowa location.
John R
