Technical => Suspension/Steering => Topic started by: streetracer on July 17, 2014, 02:34:03 AM
Title: lowering springs
Post by: streetracer on July 17, 2014, 02:34:03 AM
Anyone know what mustang springs will fit my t bird 1986 5.0?
Post by: vinnietbird on July 17, 2014, 07:00:00 AM
I used '99 Mustang springs in mine. My Bird is an '88, but would work the same in your car.
(http://i216.photobucket.com/albums/cc205/Vinnietbird/1476092_10203087322370382_522808182_n.jpg) (http://s216.photobucket.com/user/Vinnietbird/media/1476092_10203087322370382_522808182_n.jpg.html)
Post by: custompunk on July 17, 2014, 08:51:52 AM
I also have 99 mustang springs up front and moog cargo coils in the back for the 83-86 picture.
(http://i.imgur.com/YGrIDNr.jpg)
Post by: streetracer on July 17, 2014, 09:49:04 PM
thanks everyone
Post by: 50tbrd88 on July 18, 2014, 11:49:11 AM
I have fox mustang Steeda springs in the front and turbo coupe Moog replacement springs with a couple coils cut off in the rear.  Also have Fox Mustang shocks/struts with Chuck W shock adapters in the rear and Fox Mustang spindles up front.
(http://i495.photobucket.com/albums/rr313/50tbrd88/null_zps2a5e547c.jpg)
Post by: QUICKSHIFT on July 18, 2014, 02:37:03 PM
86 Mustang  GT springs here.
Post by: kylesburrell on July 21, 2014, 01:13:54 PM
I got these ones:
http://www.americanmuscle.com/forac.html
It dropped the ass a bit more than I liked. Hoping to get CHE control arms with the threaded spring perches
Post by: TOM Renzo on July 24, 2014, 09:00:52 PM
What is wrong with cutting the original springs and setting the height to your liking. Dont get me wrong i change many springs in my career but cutting is a viable option. have a great night guys
Post by: kylesburrell on July 28, 2014, 12:08:10 AM
^^Cutting springs will lower the car. But with lowering springs you can get stiffer springs. You can get progressive spring rates or constant spring rates. I noticed that my car dives A LOT LESS under braking with stiffer springs
Post by: TheFoeYouKnow on July 28, 2014, 07:14:55 AM
2000 GT front, 1999 V6 convertible rear.  At this height, the car looks right.  My roof line is visibly lower than that of my wife's 2012 Fusion.
X
Post by: GrannysBird on July 29, 2014, 05:11:13 PM
Quote from: kylesburrell;436488
But cutting the springs does change the spring rate as it is a function of coil diameter, number of coils, and thickness of the steel used to make the coil.
**SpringRate = (Thickness)/(nCoils*CoilDiameter)
So with all things being equal reducing nCoils increases ones spring rate, so yippee!
**This functional relation was obtained from the internet @ http://www.therangerstation.com/tech_library/coilspringrate.shtml (http://"http://www.therangerstation.com/tech_library/coilspringrate.shtml") and is being posted onto the internet by someone someone on the internet no warranty written, expressed, or implied.  All risk is assumed on the part of the user.
Post by: TOM Renzo on July 29, 2014, 06:30:21 PM
Removing effective coils  increases a springs  rate as explained above. Cutting springs is totally acceptable and done all the time. have a great evening guys
Post by: Haystack on July 30, 2014, 12:09:27 AM
I got sn-95 something or another springs um gonna drop in the bird. i might go with some lowered rear springs as i plan on che adjustable arms later on.
Post by: V8Demon on July 30, 2014, 02:44:36 AM
http://www.bluecoilspring.com/rate.htm
Load rating is just as important....
