Technical => Engine Tech => Topic started by: ThunderFox on June 16, 2014, 07:28:30 AM
Title: Temperature Gauge
Post by: ThunderFox on June 16, 2014, 07:28:30 AM
Just wondering here. I havent driven the car in temps above 75ish yet and the temp gauge is always at the middle or a little below, never beyond the "O". Yesterday it was about 85 and I had the A/C on the entire time. Nothing unusual on the highway or streets but when I stopped somewhere and the car was idling for about 10 minutes it went on top of the "R" and was touching the "M", and even after a burst on the highway it barely went any lower. The car sat for a few hours, then on the way home it was a little over the middle but not as high as earlier.
I know my Mark VII would normally be a touch over the middle, but does this sound unusual considering where it runs in not much cooler weather?
Thanks.
Post by: Herbsbird on June 16, 2014, 08:58:01 AM
The same thing happened to me yesterday. On the way home from a car show it was pretty hot so I had the AC on and noticed that the gauge was above the center of the normal range but it didn't go any higher. I shut off the AC to see if it made any difference but no change. Everything seems to be O.K. so I guess that is just the way the cooling system works.
Post by: turbotrav on June 16, 2014, 09:18:10 AM
Maybe the IVR playing tricks.....Instrument Voltage Regulator....
I wouldnt worry too much....if you know your cooling system is healthy.
Travis
Post by: ThunderFox on June 16, 2014, 09:30:06 AM
That is strange. As far as I know my cooling system is in good shape. It didn't go beyond the M and last week I drove about 65-70 miles round trip with only 1 or 2 30 minute stops with no A/C on(I didn't recharge it yet) in hot weather and the temp. gauge was normal. It must be how it goes with the A/C on? It still wouldn't go past the "M" but it still threw me off.
I've read the back and forth here and elsewhere, any real downside to throwing in a 180 deg. thermostat?
Also, are the 9 blade Mustang fans a direct swap?
Thanks.
Post by: thunderjet302 on June 16, 2014, 12:34:46 PM
Quote from: ThunderFox;434868
Thanks.
I've got a digital gauge in mine. It lights up three bars for about 1-2 miles driving in any condition then lights up four bars after that. Doesn't matter if it's 50* or 95* with the A/C on. It stays at four bars (half way up the gauge) all the time. I had it go to five bars once when I was running the original radiator and idling in traffic with the A/C on high and the outside temp was 100*.
As far as the 180* thermostat and the 9 blade HO fan yes they are a direct swap. I run both of them along with a Police Interceptor fan clutch. The engine runs between 180*-190* according to an infrared thermometer.
Post by: ThunderFox on June 16, 2014, 02:30:49 PM
Quote from: thunderjet302;434872
Cool, sounds like my situation is normal for hot weather and AC blasting. I think I'll pick up the Mustang fan and 180* T-stat and see how that helps.
I have to deal with a new problem that just popped up at lunch today. I went out to go to the store and the car immediately was running like . Rough idle, sputtering on acceleration, almost stalling and for some reason it sounds louder. The car ran great on the way to work. So weird...
Post by: Haystack on June 16, 2014, 07:16:12 PM
A 180° thermostat changes the dwel time the coolant sees in the radiator. anything below 180 will also make the car run rich and kill gas mileage.
if all is well, a 192 is more then adaquate. my 87 bird did well with stock 250ish k mileson the water pump and a cheap single row radiator with ac on all summer till the timing chain cover gasket let coolant out. never got above m unless the guage was acting up.
Post by: ThunderFox on June 17, 2014, 06:36:57 AM
I'll give the Mustang fan a try first before the T-Stat since it's easy. But i have to have a new cat and y pipe put on since thats why the car was runnng so horribly yesterday. Its definitely an exhaust leak and i dont think its the manifolds. Those pipes look like  so it has to be that. It wanted to stall at every light and was popping and sputtering. I knew it was on borrowed time but i didnt think a leak there would affect drivability so much.
Post by: ThunderFox on June 17, 2014, 08:34:33 AM
We'll I'm an idiot. Took it to a shop just to check the exhaust, all good. Then I ran codes, MAP sensor. Checked it out and the vacuum hose sprung a leak.
PIA bc I don't want to take the manifold off again. Is there usually a clamp on the MAP hose under the intake? What size and length is the MAP hose if anyone knows off hand?
Thanks.
Post by: Haystack on June 17, 2014, 02:24:56 PM
I use a pen housing and electrical tape as a side of the road fix.
More likely then not your motor mounts are shot allowing the engine to rock causing the hose to fail.
Post by: thunderjet302 on June 17, 2014, 03:13:33 PM
Quote from: Haystack;434914
Or he cheaped out and didn't replace the MAP hose ;).
Post by: Haystack on June 17, 2014, 07:31:13 PM
Hey, my pen roadside fix from two years ago was still on the car. i didn't even own it then. i patched it up when my buddy fixed the car.
Motor mounts seem to be made of paper for me for some reason.
Post by: JeremyB on June 24, 2014, 09:30:03 PM
Quote from: ThunderFox;434877
A 180 degree thermostat will only delay overheating if you have cooling issues. A thermostat fully opens at 15-20 degrees above what it's rated for. At 195-200, a 180 degree t-tstat if flowing the same as a 195 degree t-stat at 210-215 degrees. If you have underlying issues and get stuck in nasty stop-n-go traffic in a hot day, the 180 degree stat will only buy you a few minutes before it's running just as hot as a 195.
Post by: ThunderFox on June 25, 2014, 09:09:38 AM
Quote from: JeremyB;435132
That's all I'm looking for. AFAIK the cooling system is working properly, the radiator looks to be in good shape, there are no leaks(other than my ignorance in excluding a hose clamp from the bypass hose) and the coolant that I drained for the T-Stat install was a nice clean light green. I'm just looking for more cushion when the A/C is running full blast on a hot day. I'm going to upgrade to a heavy duty fan clutch and the 9 blade Mustang fan.
My Mark VII was in great shape and the Temp. gauge would stay a little over the middle(just not as far) on hot A/C days ad that car had no issues idling with the A/C on for hours. It still gets me paranoid though. Lol
Post by: V8Demon on June 25, 2014, 09:24:56 AM
The mark came with a thicker radiator.  3 core brass as opposed to 2 core.  I run a 3 core, 9 blade fan, SSP fan clutch, and a 180° t-stat.  With my setup, the stock stuff, I would imagine I'd overheat rather quickly on a 90°+ day.
Post by: thunderjet302 on June 25, 2014, 02:40:05 PM
Quote from: V8Demon;435162
Actually the Mark VII has the same two row brass radiator the fox Thunderbird/Cougar use. It even has the same 7 blade fan.
I've got a Northern two row aluminum radiator, 9 blade fan, SSP fan clutch, and 180* thermostat in my Thunderbird. Never goes past half way on the stock temp gauge.
Post by: V8Demon on June 25, 2014, 04:36:41 PM
The 3 row I picked up was listed for a Mark VII at the parts store.  No mention of it in the computer for a Tbird or Mustang.  Weird.  Maybe a full size box Panther chassis was the OEM?
Mine is a Visteon.  They made the OEM radiators for Ford.  Not sure who does now.....
Post by: ThunderFox on June 27, 2014, 04:50:17 PM
Well the car still goes to "M" with A/C on after a little while during an hour long trip yesterday in high 80 deg weather. Im pretty sure it's the fan clutch since its the stop and go/ low speed driving it can't overcome. When cruising on the highway even with A/C on the temp starts to drop. I wonder what temp it really is on the "M"? Does anyone know the range of temperature for the stock buttstuffog gauge? I dont think it was near overheating or maybe that's normal operating temp, stock gauges suck. I should get a manual gauge for the A Pillar.
The fan clutch has a lot of gunk at the front. I picked up a HD fan clutch from Advanced and once I feel btter Im going to put it on with the 9 blade Mustang fan. I can't see it being anything else at this point.
Thanks for all the help and info so far.
Post by: thunderjet302 on June 28, 2014, 11:41:36 PM
Gunk in front of the fan clutch means it's shot. Especially if it gets warm in traffic and it's fine on the highway.
Post by: ThunderFox on June 29, 2014, 09:47:58 PM
Put on the new HD clutch and Mustang 9 blade fan and wow, what a difference. If you put your hand over the engine you can feel it blowing at idle. Did a 30 mile trip which included a 10-15 minute initial idle warm up and without the A/C on it stays between the N and O even in consistent low speed driving. With the A/C on it didn't budge past the middle, beginning of R at the most and immediately drops when the A/C is off, not bad. It was high 80's today too. Hopefully this is done. Lol Thanks all for the help and tips.
