Technical => Body/Appearance/Interior => Topic started by: V8Demon on March 29, 2014, 10:43:04 AM
Title: Dash cluster cover plate
Post by: V8Demon on March 29, 2014, 10:43:04 AM
Anyone have luck getting rid of haze on the supposed-to-be-clear cover plate that goes in front of the dash cluster?  I used a mildly abrasive wax on mine yesterday and it laughed at me.  I'm debating on picking up a headlight lens cleaning kit and giving it a shot.  This plastic seems softer though so I'm leery.
Post by: custompunk on March 29, 2014, 11:18:11 AM
I have never tried this on the plastic so this is not a recommendation.  This is just how I clean headlights.  Buffing wheel, rubbing compound.  It will scratch it/clean it.  Then a coat of clear coat over it.
Post by: thunderjet302 on March 29, 2014, 11:19:20 AM
Meguiars Plastic X worked pretty good on mine. You could also try their Ultimate Compound followed by Plastic X. That has worked well for me on clear plastic before.
Post by: vinnietbird on March 29, 2014, 11:22:29 AM
x-2. I had a nearly white lens that I was able to rescue using the plastic X.
Post by: V8Demon on March 29, 2014, 11:29:12 AM
ok.  I'll give it a shot.  ;)
