General => General Fox T-Bird/Cougar Discussion => Topic started by: 88tc on June 27, 2005, 02:24:00 PM
Title: Weak Takeoff
Post by: 88tc on June 27, 2005, 02:24:00 PM
I just got this 88 turbo coupe this doesnt even want to take off at the light once turbo kicks in its fine. What can i do i checked timing, plugs are good.Thanks for any advice.
Title: Re: Weak Takeoff
Post by: Chuck W on June 27, 2005, 03:11:00 PM
Again....http://www.turboford.org
They are dogs out of the hole unless you slip the clutch a bit to build some boost off the line.
Go to the sites I posted in your other thread.....there's info here.  Not too many TC guys here...
Post by: Funky Cricket on June 27, 2005, 04:42:48 PM
well you are trying to move a 3600 lb car with a 4 cyl. Until the turbo kicks in, its not going to move that well.
Post by: Tbird232ci on June 27, 2005, 04:47:18 PM
learn to launch it
Post by: oldraven on June 27, 2005, 06:07:13 PM
Bring it to 3500 and drop the clutch. That should take care of your launch issues. :) Anyway, it's called boost lag. Until the turbo kicks in, you're just driving a boat with a low compression fourbanger.
