Marketplace => T-Bird/Cougar Parts & Cars WANTED => Topic started by: jcassity on January 02, 2014, 09:49:07 AM
Title: Trottle body and spacer
Post by: jcassity on January 02, 2014, 09:49:07 AM
looking for a decent trottle body and spacer for a new 5.0 build i am doing.
something better than stock
i wont haggle, just gathering parts for this project.
Post by: Haystack on January 02, 2014, 05:15:05 PM
better then stock as in h.o.? I have a throttle body and egr spacer of an h.o. motor.
Post by: jcassity on January 02, 2014, 05:58:40 PM
well,,  i think thats 55mm?
need to ask about the bore diameter on that PP intake im getting.
Post by: 88turbo on January 02, 2014, 06:40:54 PM
I have one from an explorer, 65mm.
Post by: Haystack on January 02, 2014, 07:14:34 PM
professional products edelbroke rip off should be 70mm.
Post by: jcassity on January 02, 2014, 07:40:03 PM
Quote from: 88turbo;426657
Pls sell if you can.....
i  just noticed the explorer upper is kinda "knecked" inward but its actually 73mm just an inch up into the bore.
Post by: jcassity on January 02, 2014, 07:44:02 PM
Quote from: Haystack;426659
yeah,,, i hear ya!,,,good part is my cash is staying in the country.
even on masons build not a dime went to another countries stock exchange.
been wondering whats up with the PP intake tag saying made in USA.
Post by: 88turbo on January 02, 2014, 08:09:27 PM
Quote from: jcassity;426666
are you interested? I have no need for it.
Post by: jcassity on January 03, 2014, 08:14:34 AM
yep, sure am...
sad part is i tossed out a couple stock TB's,, totally forgot to save the shaft to transition it over... oh well
Post by: 88turbo on January 03, 2014, 05:32:11 PM
I'm sure someone here might have one! lol
Post by: jandmmustangs on January 03, 2014, 05:59:55 PM
I have a stock HO unit. No tps or iac. Cover the shipping and its yours
Post by: thunderjet302 on January 04, 2014, 11:09:23 AM
As a FYI: the opening on the stock Explorer GT40 upper is 68mm-70mm depending on how it was finished. I've measured 4 of them and one was 68mm, two were 69mm, and one was 70mm. All of them were off 96-97 Explorers. I have the one with a 70mm opening on my Thunderbird right now as I'm running a 70mm TB. You can open them up easy but since I had 4 laying around it was easier to just use the one with the correct opening.
Post by: jcassity on January 04, 2014, 12:39:58 PM
check yours again,,
i was measureing about 1'' or so up inside the bore,, not the actual end of the bore.
i noticed the bore on the end where the spacer mounts kinda tapers inward a little.
Post by: jcassity on January 04, 2014, 12:40:35 PM
Quote from: jandmmustangs;426708
thank you,, send me your addy on pm and i will get you a post office money order out monday.
Post by: jandmmustangs on January 05, 2014, 01:13:04 PM
Pm sent. Hopefully ya got it. My ucp isn't showing I sent it
Post by: jcassity on January 05, 2014, 04:24:57 PM
good to go,
gotta get money orders out tomorrow myself.
Post by: thunderjet302 on January 06, 2014, 09:37:37 PM
Quote from: jcassity;426738
check yours again,,
I measured mine at the end of the bore. I wanted it to be the same size as the throttle body/EGR spacer. It may be bigger past the end of the bore. I do have another upper sitting in the garage I can measure. It does look slightly larger beyond the . The most important thing is that the end of the bore is the same size as the throttle body/EGR spacer and not smaller.
Post by: jcassity on February 09, 2014, 04:15:24 AM
ttt
still need 65mm tb and spacer
