Technical => Electrical Tech => Topic started by: jcassity on December 18, 2013, 01:01:48 PM
Title: 88 door lock actuators
Post by: jcassity on December 18, 2013, 01:01:48 PM
For the 88 birds,, even having slight differences in the evtm with respect to wiring......................
the question is..............
Are the 1988 door lock actuators compatible with 83-88 Fox's  being a bird or coug?
for some reason i seem to believe ethat these actuators were used from as far back as 1980 across many breeds of cars like broncos ect ect.....
Post by: EricCoolCats on December 18, 2013, 02:06:10 PM
Yes. Many Fords used the same ones.
Post by: jcassity on December 18, 2013, 09:13:06 PM
thanks,, was just curious about the phyical design of the 88 door actuators compared to 87 and down,, for some reason i thought there was a little difference.
Post by: TheFoeYouKnow on December 18, 2013, 10:26:50 PM
In many cases, the actuator itself may be the same, but the length of the rod attached to it may be different (due to different distance between the latch arm and the mounting rivet of the actuator).  I don't mean the rods in the door, but the hook that's a part of the actuator itself.
Post by: thunderjet302 on December 21, 2013, 12:35:24 PM
I think it's possible to change out the rods on the actuator but I haven't tried it. This way you could run an actuator from any Ford and just swap the arm out. I've got a dead one from the driver's side on my Mark I might experiment with over the winter.
Post by: EricCoolCats on December 21, 2013, 03:29:16 PM
Yes, it is possible...I've done before. It sucks to have to disassemble a new actuator to change out the rod, but at least it can be done. A metal catch, a few ball bearings...all there really is to it.
Post by: V8Demon on December 21, 2013, 08:41:08 PM
I've had nothing but bad luck with fox body door actuators..... Hence my thread in the Parts wanted section.  Some of the aftermarket kits come with an assortment of rods to change out.
Post by: jcassity on December 22, 2013, 10:29:16 AM
i am baffeled by why these are not just solenoids,, instead of motors memicking the actions of a solenoid.
Post by: TheFoeYouKnow on December 22, 2013, 10:35:39 AM
Nope, solenoids.  Not motors. I've had them apart.
Post by: jcassity on December 22, 2013, 08:44:42 PM
i have to, they spin around in circles,, the internals that is and that manipulated the spiral rod up and down.
the internals of our actuators dont "pop" up and down like a real traditionally accepted solenoid should.
besides,, ours also have burshes .... take another looksee
if you bench test the unit off the car and put 12v on it,, the rod will spin around in circles and not stop.
