Technical => Suspension/Steering => Topic started by: flylear45 on November 29, 2013, 10:36:31 AM
Title: Sway bar bushing replacement
Post by: flylear45 on November 29, 2013, 10:36:31 AM
Helpful tip for the day. When you go after sway bar bushings,
1. Put front of car up on jackstands
2. Loosen sway bar bushing mount bolts on one side
3. Put jack on opposite lower A-arm and jack up a couple inches
This will put slack in the side you are replacing and you can just slide the old one off and the new one on.
