Technical => Engine Tech => Topic started by: 5.0thunderbird on October 21, 2013, 06:30:23 PM
Title: Motor mount question.
Post by: 5.0thunderbird on October 21, 2013, 06:30:23 PM
What motor mounts work with a 86 thunderbird for a 5.0?:D Thanks to anyone who responds
Post by: Haystack on October 21, 2013, 08:30:57 PM
they are specific to 86-88 cougars/tbirds.
chuck w makes after market mounts.
Post by: 5.0thunderbird on October 21, 2013, 09:04:56 PM
mustang ones wouldnt work?
Post by: 5.0thunderbird on October 21, 2013, 09:07:35 PM
http://www.summitracing.com/search/year/1986/make/ford/model/thunderbird/part-type/motor-mounts-and-inserts?SortBy=Default&SortOrder=Default this is what summit has to offer
Post by: vinnietbird on October 21, 2013, 10:30:06 PM
Mustang mounts are different...unless you change the K-Member. It would be MUCH easier to swap the mounts. Either the cushions (can be found at Autozone), or buy the ChuckW mounts, call it a day, and never need new ones.
Post by: Haystack on October 22, 2013, 02:37:03 PM
just get the chuckw ones. I'm about to swap mine again. 3rd time this year, and 4th since I bought the.car last November. I am really sick of swappingbthem, so im gonna try to get some money together this winter and swap the chuck mounts in and hopefully never have anymore problems.
Post by: mcb82gt on October 23, 2013, 10:25:10 PM
I would definately recommend the Chuck mounts.  I had them on my 2.3Turbo,  nice pieces.
Post by: bigbada1 on October 24, 2013, 12:19:31 PM
I have a brand new set of Chucks Mounts that were never used I would be willing to let go for $150 Shipped I also have a set of used stock 5.0 mounts that I would sell for $50
Post by: JaneyBird on October 27, 2013, 04:01:18 PM
I would agree you need motor mounts lmao
Post by: Haystack on October 27, 2013, 07:59:12 PM
wanna quickly identify a sefi 5.0 cougar bird at the junkyard? look for a dent in the middle front of the hood. its from the ac bracket hitting the hood when the mounts let go.
Post by: jcassity on October 27, 2013, 09:53:05 PM
the only thing i had trouble with is the dead nuts engineering on the mounting.
there is absolutly no wiggle room when you pass the bolt through the mount and line up to the motor.
we had to set the mounts in the bay and then drop the motor down on top of chucks mounts,, it was nothing short of a mother f'er to get the second bolt in on each one.
I also wish the bolt heads had a wide shoulder like head bolts,, too much hardware to track, a simple bolt with shoulder and lock washer would be fine.
great mounts, great design, great money spent,, i would do it again 10 more times if i had the demand.
so yes,, go to chuck mounts,, or .... i may have a set coming up for sale that came off my son's bird.
we will resto my white coug for my younger son Chance and he might as well have chuck mounts to.
Post by: Haystack on October 27, 2013, 10:15:28 PM
I've been talked into it. I crawled under the tbird today and checked the motor mounts. I again broke 2 bolts off inside of the block. guess the stock setup really can't handle the torque multiplication of the t-5 and aggressive driving. my aod rubber mount is also shot. if I take off normally, the shifter moves 2" and if I nail it from a stop slipping the clutch to keep from tire spin, it actually touches the shifter to the otherside of the shifter trim.
I'm really tempted to go with a stang k member and solid mounts, or even better, a motor plate.
Post by: mljames on October 29, 2013, 08:27:00 PM
If those chuck mounts are still available please PM me mine just broke and I don't want to go through this again
Post by: jcassity on October 30, 2013, 08:50:43 AM
just pm Chuckw here
Post by: thunderjet302 on October 30, 2013, 02:16:25 PM
Quote from: Haystack;423848
How do you keep breaking the stock mounts? I've got the stock brackets with the rubber isolator from O'Rielly Auto Parts and I've yet to break one. My cars got a 2800 stall converter, 3.73 gears, 180-200 more HP than you car and I launch it at the track. You must really be beating the hell out of your car :burnout:.
Post by: Haystack on October 30, 2013, 06:20:37 PM
I'm not known for leaving anyplace without at least a tire chirp in first.
the torque multiplication of your setup should be about 10x in first gear. mine is about 9.1 with the 3.35 first gear and a 2.73 rear. its also not uncommon for me to have 600-800 lbs worth of tools in my trunk.
Post by: HAVI on October 30, 2013, 06:52:56 PM
Chuck W's FTW :headbang:
Post by: thunderjet302 on October 31, 2013, 11:56:31 AM
Quote from: Haystack;423931
Well that might do it ;). I never go WOT from a stop on the street. The only time I do that is at the track. If I try to leave a stop with anymore than 1/3 throttle it just spins the tires.
Post by: jcassity on November 01, 2013, 08:21:15 AM
when we took out my son's motor this past summer, im staring at the engine coming up kinda in a daze, like i was day dreaming..
my son asks whats up and i said...
how in the hell is it that the motor stayed int he car.
he looked and didnt understand the impact yet
one half o the mount on the frame, the other half bolted to the block.
both mounts had separated through the middle of the rubber isolator.
