Technical => Electrical Tech => Topic started by: tonyboy on September 15, 2013, 08:53:43 AM
Title: 88 t bird t c
Post by: tonyboy on September 15, 2013, 08:53:43 AM
i need some help is there a fuse for the abs relay if so where is it located on the car
Post by: TOM Renzo on September 15, 2013, 09:25:59 AM
YES Fuse link N On the starter solenoid
Post by: tonyboy on September 15, 2013, 09:41:39 AM
is it near the battery
Post by: softtouch on September 15, 2013, 08:01:45 PM
Read the following thread. It is an 87 and the fuse link is called "E" instead of "N", but otherwise it is the same as your car.
http://www.foxtbirdcougarforums.com/showthread.php?35671-Brakes-have-failed-mech-cant-help&highlight=brake+relay
Post by: TOM Renzo on September 16, 2013, 06:21:53 AM
Actually
ALL Data says an 87 and 88 are different. His post said he has an 88 !! They both come from fuse links from the starter solenoid.
87 HD Pump Link C Relay is link  B  16G
88 HD is S link and relay is T  16G
So the link you want is T Black 16G
I also gave you the wrong fuse link N That is from the ignition switch to the ABS sorry. I read your post to fast i just noticed  you want the Fuse link for the relay. My Mistake Sorry i stand corrected it happens.
