Technical => Engine Swapping => Topic started by: ricktjr on August 08, 2013, 05:32:16 PM
Title: 460 Swap With stock K Member?
Post by: ricktjr on August 08, 2013, 05:32:16 PM
Has anyone done a 460 swap and used the stock K member? If so how did it work out for you?
Post by: Chuck W on August 08, 2013, 11:08:21 PM
Quote from: ricktjr;419711
Might want to be a bit more specific about what year car, seeing as they weren't the same from 83-88.
Post by: ricktjr on August 09, 2013, 04:38:04 AM
1987 Cougar.
Post by: 83-88T-Bird Guy on August 13, 2013, 12:24:11 PM
I sent these pics to Rick in a pm, but for future reference to those that search, I will offer my experience.
These are pics of solid mounts I made to fit the 460 in my 87 TC. n
One pic shows the upper half of the mounts on the 460 (on the cherry picker)
When I made them, I was using D5 exhaust manifolds.
In order to use my turbo headers, I had to use large nuts (as spacers) to raise the engine that amount, so that is what you see in the pics.
Putting the 460 in there is do-able with the 86-88 k-member, but you have to make your own mounts.
(http://i148.photobucket.com/albums/s3/83-88T-BirdGuy/DSCF1942.jpg) (http://s148.photobucket.com/user/83-88T-BirdGuy/media/DSCF1942.jpg.html)
(http://i148.photobucket.com/albums/s3/83-88T-BirdGuy/DSCF1940.jpg) (http://s148.photobucket.com/user/83-88T-BirdGuy/media/DSCF1940.jpg.html)
(http://i148.photobucket.com/albums/s3/83-88T-BirdGuy/DSCF1957.jpg) (http://s148.photobucket.com/user/83-88T-BirdGuy/media/DSCF1957.jpg.html)
Post by: thunderjet302 on August 13, 2013, 12:45:30 PM
I'm guessing the 460 won't fit under a stock hood with the spacers you added? I know you got it to fit before without the spacers but it was tight.
Post by: 83-88T-Bird Guy on August 13, 2013, 04:29:14 PM
Quote from: thunderjet302;419988
Actually, even with the motor mount spacers and a 1/2 inch phonelic carb spacer, the 14 x 3 Moroso drop base air cleaner barely cleared the duct-work for the hood vents.
Yes, I am using 1/2 inch k-frame spacers as well as offset rack bushings for the manual steering rack. That's good for 1/2 inch.
Here are some pics of the install completed:
(http://i148.photobucket.com/albums/s3/83-88T-BirdGuy/TCenginesilver1jpg.jpg) (http://s148.photobucket.com/user/83-88T-BirdGuy/media/TCenginesilver1jpg.jpg.html)
(http://i148.photobucket.com/albums/s3/83-88T-BirdGuy/TCenginesilver3jpg.jpg) (http://s148.photobucket.com/user/83-88T-BirdGuy/media/TCenginesilver3jpg.jpg.html)
(http://i148.photobucket.com/albums/s3/83-88T-BirdGuy/TCenginesilver4jpg.jpg) (http://s148.photobucket.com/user/83-88T-BirdGuy/media/TCenginesilver4jpg.jpg.html)
Post by: thunderjet302 on August 13, 2013, 06:23:22 PM
Ah so it did still fit. I'm guessing sans K-member spacers it wouldn't fit under the hood?
Post by: 83-88T-Bird Guy on August 14, 2013, 12:14:14 PM
Quote from: thunderjet302;420005
Correct, because the top of the spark plug wire boots on the dist. cap are now touching the plastic air scoop ductwork on the hood.
However, I have never took that scoop stuff off to see how much more clearance there is.
I left it on in case I get caught in the rain, then the water would just get the right side if the engine wet and not the distributor. (plus it looks better than without)
Post by: thunderjet302 on August 14, 2013, 08:37:09 PM
Quote from: 83-88T-Bird Guy;420052
I wonder if a 460 would fit with a non Turbo Coupe hood and no K-member spacers?
I alwas thought this would look cool under the hood of a 4-eye Thunderbird
[ATTACH=CONFIG]32666[/ATTACH]
Post by: 83-88T-Bird Guy on August 19, 2013, 07:05:09 AM
Quote from: thunderjet302;420064
I don't see any reason a 460 would not fit under a stock T-Bird hood. (without spacers)
My Gray 460 Bird does not have spacers and if I put the hood back down, I'm pretty sure the air cleaner will clear the hood.
Probably have to use a Moroso style drop down base air cleaner and a 14 x 3  filter.
Post by: 1BadBird on August 19, 2013, 06:47:59 PM
Don't give me any ideas Lou :evilgrin: I might just have to do that but maybe with a 5spd behind it.
Sorry OP, not trying to hi-jack your thread
:bowdown:
Post by: Dougy_Fresh on August 20, 2013, 12:21:54 AM
Alan, what headers are those?
Post by: 83-88T-Bird Guy on August 22, 2013, 12:27:53 PM
Quote from: Dougy_Fresh;420336
A company in southern California made those ( might still make them)
I believe they were called CPR.
Nice quality.
I think I kept their link on another computer.
Anyway, I bought them from a seller on fleabay years ago and had those mid-lengths jet hot coated after I modified them to fit the TC either way.
My plans at the time was to run twin turbos up front.
Post by: pegasus on September 03, 2013, 12:04:47 PM
I cant see how a 460 would fit without the spacer I had to cut out the hood bracing so my holly air filter would fit on top of my 302 with a 1inch carb spacer but I'm going the next step and getting a hood scoop for my car Saturday at the swap meet
Post by: erik draven on October 02, 2013, 10:47:08 AM
What intake is that
Post by: dragracer on October 14, 2013, 12:51:28 AM
Quote from: 83-88T-Bird Guy;419985
Allan,
I just happen to stumble across a link to this thread and i'm grateful i did. I've got an 88TC i purchased new but had issues with the auto tranny about 5 years ago and simply parked it in the yard after buying a new SUV. I've very interested in your 460 swap using the stock K member. I've read on several forums where they replaced the stock K member with one from a Mustang but this direct swap you've made is just the ticket i've been looking for. I do have a few questions concerning the solid mounts you fabricated. Do you have any drawings with dimensions you could share? If not, would you be willing to fabricate a pair for me at a cost of course?? I'm not a welder so buying the mounts already made would be the best bet for me. The car will only be used for local bracket racing with a mildly built 557 and an automatic, probably a C4 or a glide. Oh, forgot to ask what you did about the ride control suspension on the car???
Thanks in advance for your help. I was leaning towards buying a fox body Mustang coupe to build a dragcar when i remembered i had a fox body Bird just sitting around. Hopefully your advice will allow me to pursue doing something with the car.
Frank
Post by: 83-88T-Bird Guy on January 14, 2014, 10:36:13 AM
Quote from: dragracer;423354
Allan,
Frank
Sorry for the late response Frank.
I need to get on here more often. lol
Unfortunately, I do not have any blueprints on the mounts.
Because I wanted my 460 to sit as low and as far to the rear as possible, it took a lot of time designing and trial fitting those solids.
Plus, I wanted to be able to slide the engine forward enough to get the bellhousing bolts off so I could pull the engine but leave the trans still in place.
A 460 is in the car right now so I cannot get you some dimensions on the mounts.
Hopefully, this year I will get the car out of storage and pull that 460 out. If I do, I will try to remember to get dimensions.
Alan
Post by: 83-88T-Bird Guy on January 14, 2014, 10:37:50 AM
Quote from: erik draven;422781
What intake is that
The intake on the black 460 is a '74 or '75 (stock) car intake I believe. (cast iron)
