I was wondering, after doing a search of the past threads, if using the 88 5.0 Mustang GT/LX brake booster with the Cougar master cylinder would be beneficial with 11" Mustang front rotors, calipers and pads? I have the 10" drums in the back and do not plan any changes to those right now. I know the 5.0 fox Mustang (87-93) brake booster is smaller in diameter but longer than the Cougar's or the 2.3 Fox Mustang that came with the 10" rotors. Any ideas what would work best?
My thinking was that the 10" front rotors got the larger diameter/shorter booster and the 11" front rotors got the smaller diameter/ longer booster?
No need to change the booster if the only mod you are making is swapping fro the 10" front brakes to the 11" front brakes. The booster change is basically when you swap over to the SN95 brakes.
Darren
Changing over to the booster to a '93 Cobra booster just makes the car stop with less pressure applied to the brake pedal?
Its a little more complicated than that but in a nutshell yes. The booster is sized to the application just like the MC is. For your application they used the same booster for the 10" and 11" brakes.
Darren
The upgrade from 10" front rotors to 11" front rotors requires changing spindles to Mustang spindles.
Does that mean an change is needed to Mustang struts also?
More than likely the 87-93 5.0 Mustang spindles will be what you can source. The 87-88 Thunderbird Turbo Coupe spindles will work as well but are a bit harder to find.
The difference between the struts is the mounting point to the spindle. The TC or 87-93 5.0 Mustang spindle is narrower at the strut mount versus the other spindle. You can get hardened washers to shim the gap if you want to reuse your existing struts. If you are going to replace your existing struts then get the 94-95 5.0 Mustang struts if the car is stock height or get the 87-93 5.0 a Mustang struts if you have the car lowered more than an inch. Some may say it is not necessary if the car is lowered but they do not understand that the SN95 struts are about an inch longer and will not compress as far as the Fox strut.
Darren
I have fox Mustang spindles and did run T-bird struts for awhile. Like Darren said, you can just make up some spacers. Now I run Fox 'stang Tokico blue's front and rear (Chuck W adapters in rear). I also have Mustang 11" brakes w/Lincoln calipers and a TC rearend w/disks and am currently still running the stock T-bird booster and MC. Pedal is a little "spongier" feeling than stock but it does seem to stop shorter due to the larger rotors/calipers.
The spongy pedal feel that 50tbrd88 is experiencing can be several things but one thing for sure is that it can be fixed.
One thing to check is if you are getting full lock up on a panic stop. If you are not you may need to adjust the booster rod tip further out. 1/2 turn on this is a HUGE adjustment. My guess is that you still have air in the lines, water in the brake fluid, or you need a new/different master cylinder.
The comment with regards to air in the line is one I make due to too many times I have heard that there is no way there is air in the system only to find there is. Power bleeders are the only way to go if you can get your hands on one or just buy one. I know $50 is expensive to some for one of these but I like to stop. I'm always amazed at how we will drop $500+ into a set of cylinder heads to go faster but the brakes get ignored.
The master cylinder comment is from the plunger seals wearing and the brake fluid bypassing and the pedal getting that mushy feeling. Another problem with MC's is being improperly sized to the application. With the 73mm single piston front calipers and the TC rears you really need to run a MC with a 1" bore like an 85 Lincoln town car. That's just my opinion so do some research first.
Darren
One other thing that may or may not be relevant to the OP's situation;
For those (like me) that have a double adjustable clutch cable, you'd highly benefit from swapping the booster to a Mustang so that you can adjust the firewall end of the clutch cable. If you've got the SN95 brakes up front, it's almost a "must do" thing.
Depending on the age of the components, the spongy feeling can also be the result of old flex lines that swell under pressure. On mine, just upgrading to stainless lines made a noticeable difference.....and the rubber ones weren't that old.
My MC and booster are original '88 parts so I'm sure they are not performing like they were 20 years ago, lol. I don't race my car or drive it that aggressively so I really am not concerned about it for now. Its more than enough to slow me down from the speeds my 5.0 HO can achieve ;). I drive like a grandpa these days anyway.
Long term I do plan to upgrade to a different MC and booster and then maybe do a clutch cable that is adjustable at the firewall. Brake fluid probably does need flushed and changed again. I do remember last time I worked on the brakes, I had a hard time getting them bled. I think I even eventually took the car to a mechanic in town and had him bleed the system. It took him a good while IIRC.
I have the 11" brake with LSC rotor package from SSBC. Get a master cylinder from a 93 Cobra. Maximum Motorsports has them. Pedal fell will improve. It's spongy with the stocker.
The 93 Cobra MC has metric threads where the 85 Lincoln Towncar has standard threads. If a person does not mind changing the brake fittings (this requires a double flare tool) or getting the adapters (Weatherhead fittings) then the Cobra unit is nice because of its update looks compared to the older units.
Maximum Motorsports also has a kit that adapts the 1993 Cobra or 94/95 MC into an 87-93 Mustang:
http://www.maximummotorsports.com/store/index.php?main_page=product_info&products_id=673
They also have good instructions on how to install the MC with their plumbing kit which addresses the booster rod adjustment issue:
http://www.maximummotorsports.com/content/install/pdf/brakes/MMBAK-3r5.pdf
Darren
Good info guys, thanks.
